View Full Version : LS1 Stand Alone Wiring Harness
JerseyGuy
12-21-2013, 09:17 AM
Can anyone give me an idea on who sells a harness that's reasonable in price.
Im new to this and a little confused.Its for a ls swap into a 69 camaro with 4l60e.
I need the computer also.There are so many I don't know where to start.
Thank You
Z06vet
12-21-2013, 10:03 AM
You'd need to know what year the motor is & what is came out of ( or at least if youre running a cable TB or DBW. Also if its 24x reluctor or 58X). I like to use John at Modern Vintage Systems. (317 224-6689) Very knowledgeable and great guy to talk to. He's done 5 for me so far. They can build from scratch or modify your donor harness. You can also run one of the aftermarket harnesses from several different companies.
cmac06
12-21-2013, 10:36 AM
None are reasonable IMO. You can get an OEM harness fir a lot cheaper and do the modifications yourself. LT1Swap has the pin outs for all the factory computers. Now if you don't want to do the work, and are lazy like me BP Automotive did mine harness, and it is a one of the most complete I've seen. The small details matter in getting the lengths right for your car are important, and he made mine to fit my Chevelle without having to do a lot of splicing. I've gone with other harnesses before, but this one was the nicest I've used by far.
Blevinator
12-21-2013, 10:11 PM
Check out PSI Conversions
Top notch
Custom tailored to your setup
$300 cheaper than most others
Don't mess around with junk yard wiring
Engine \ cabin fires are no joke.
Mizzouri
12-22-2013, 06:35 AM
Top notch
I have PSI's LS1 computer & harness and it was very easy to get going and the price point was right. Especially after I sold my stock computer and harness for $250...
Classic Nova & Performance
12-27-2013, 03:32 PM
We've used PSI and would recommend them. Very easy to deal with and knowledgeable on the issues you will need to address.
GBNL
12-27-2013, 03:39 PM
I use nelson out of san antonio tx, never had an issue with them. I really recomend them nice clean and easy plug and play harness.
1967ls2
02-28-2014, 09:20 PM
Current performance, awesome harness, not one issue so far
