View Full Version : Installation of Lokar e-brake cable
RamAir
12-18-2013, 01:09 PM
I am confused regarding installation of the e-brake cable on by Kore3 C5 rear brake. I have the Lokar EC-80 cable and its include a spring that I thought should be mounted between the clevis an the e-brake bracket. Unfortunately the spring is to long, so should I cut it ? I have seen installations on the net were the spring has been skiped, but I thought that this must be installed. Any help on this, pictures say more than thousen words !
83hurstguy
12-18-2013, 01:55 PM
Trim that spring!!! You may have the wrong clevises too... this is the only pic I have available. Tobin has the part numbers in the instructions.
87380
RamAir
12-18-2013, 02:45 PM
I will check the instruction tomorrow, i have the lokar EC-80CC. What clevis are you using, its hard to see on the picture. I find a tread here with a installation with out spring. I thought the spring was needed to return the cable to the initial position.
https://www.pro-touring.com/threads/92941-1st-gen-Camaro-Firebird-C5-disc-brake-parking-brake-soloution
83hurstguy
12-18-2013, 03:07 PM
EC-80WC
http://www.summitracing.com/parts/lok-ec-80wc
RamAir
12-18-2013, 11:23 PM
Thanks, I have order wrong clevis .....
67rally
12-19-2013, 07:36 AM
How are you connecting the Lokar cable to the factory setup?
I posted my install in this this guys thread (post #14): https://www.pro-touring.com/threads/93611-What-parking-brake-cable-kit-to-use-with-Wilwood-rear-disc-brakes
The takeaway point is that if you are retaining the brake cable spring at the front of the car, you can eliminate the Lokar springs at the rear.
RamAir
12-19-2013, 09:16 AM
My plan was to replace only the rear cable. Thanks 67rally.
Apogee
12-19-2013, 10:54 AM
Your clevis looks correct to me (Lokar #EC80CC), you just need to shorten the spring or eliminate it as noted previously. Am I correct that the clevis slides freely down the actuator arm so that the cable is inline with the clevis, and it's just the spring keeping it from doing so?
Tobin
KORE3
67rally
12-19-2013, 12:13 PM
Right, so if you keep the original style front cable with the spring already on it, you would just get rid of the springs on the rear and cut the cable to the correct length.
There are two styles of clevises (clevi?). There's a Corvette style and an Explorer style. If I recall the Corvette style didn't work with my brakes and had to switch to the Explorer style. I'll go back and see if I have the part numbers.
67rally
12-19-2013, 12:21 PM
Ok, from what I can recall/dig up from my old posts, the Covette style clevis (EC80CC) did not fit on my Wilwood brakes, it is meant for Baer brakes. I had to use the Ford Explorer style (EC81FC) with my Wilwoods.
Obviously Tobin will have a better idea of what will fit his C5 brake kit.
Here's a pic showing the subtle differences:
Top: Corvette
Middle: Explorer
Bottom: Wilwood
https://static1.pt-content.com/images/pt/2013/12/clevis_zpsaeebf2df-1.png (http://s228.photobucket.com/user/modi_photos/media/clevis_zpsaeebf2df.png.html)
RamAir
12-19-2013, 02:14 PM
I have the 80-CC. Tobin, it fits perfect just as it should. To night I removed the spring and it seems that all parts returns just as it should. Probably I will test the new brakes and the E-brakes during the weekend if we dont get any snow here in Stockholm......
formula jg
04-06-2014, 05:24 PM
Is it ok to cut the Lokar spring down to fit the ebrake drum bracket and use the OEM front cable setup that already has a spring on the cable?
