ADiCarlo
12-17-2013, 03:16 PM
So I'm considering picking up a set a wheels that have a 6.85 backspacing for the rear but it seems everyone is running sub 6 inches (5.5 5.75). After doing some research I found 1 Camaro running this set up but not much info.
Does anyone know what the WMS size of the axle is for Gordon Rojewski's car (seen below) also what's the maximum backspacing that can be run. I know that backspacing has to do with the axle size and DSE runs a 54.75 narrow axle housing (I have a quadralink plus DSE mini tubs) but they recommend a sub 6 inch backspacing also.
Post about Gordon's car:
http://www.lateral-g.net/forums/showthread.php4?t=41467
https://static1.pt-content.com/images/pt/2013/05/CamaroGordonRAD10LagunaGray_zpsd31de1dc-1.jpg
Right now the wheels sit as 18x10.5 but are 3 piece and can be widened to 11 or 12 by changing the lips but this wouldn't adjust the backspacing seeing the inner barrels would be the same.
Currently the wheel is set at 18x10.5 +28 offset. (calculates to 6.85 BS)
My fear is that the 7 inch inner barrel may be too much and hit the inside of the suspension or rail even with mini tubs or that I have to run a large rear axle.
