View Full Version : Baer 6P caliper
medbali76
12-10-2013, 11:56 AM
Do you guys know what are these holes on the rear caliper?
There is nothing on the front caliper only on the rear.8693186930
Schwartz Performance
12-10-2013, 04:25 PM
Which holes are you talking about? All I see is brake bracket holes?
medbali76
12-10-2013, 11:00 PM
The 4 holes on the rear caliper I marked with the arrow. Maybe I did not describe correctly. Actually it is not a "hole" but there is a white plastic ring inside tightened with a screw. What is the purpose of that thing?
12-11-2013, 12:44 PM
Sheesh, I only looked at the first picture, my apologies!!
They are used as bumpers for traditional non floater axles, so if the rotor moves, it hits the white material first instead of hitting the caliper. The bolts thread into blind holes, so they're not leak points or anything.
-Dale
medbali76
12-11-2013, 01:59 PM
-Dale
Thank you very much!
alphaenvirmgt
12-19-2013, 07:33 PM
There is an intermediate bracket that goes between the e-brake bracket (bolts to rear end housing flange) and the caliper. Got to have it all to work!
Conrad
"alphaenvirmgt"
