View Full Version : Power steering and ac for ford coyote
48prerunner
12-09-2013, 01:01 PM
Not sure if this is where to post this but didn't seem to fit anywhere. 86898 this is the set up from KRC. Looks like a pretty clean set up my only concern is the added load or stress on the water pump.
This is Vintage Air's set up86899runs off the crank pulley.
Anybody have any experience with either or opinions on which would be a better one to buy?
Bryce
12-09-2013, 02:24 PM
I really like the KRC pump.
tigerracer
12-09-2013, 07:38 PM
I have used the Vintage Air unit. Installation was easy and belt alignment is right on.
Running AC with the KRC unit might be a challenge.
Dale
Dales Restoration
San Berdoo
Peter Mc Mahon
12-09-2013, 07:50 PM
I have the Ford system. Belt alignment was right on, but like some other systems, no AC.
48prerunner
12-10-2013, 04:42 AM
Dale
Dales Restoration
San Berdoo
Thanks Dale good to hear from somebody that has tried it, I talked with a guy who swapped a coyote in a Galaxie and they liked it also. They had a pile of coyote flywheels for sale at swap meet is how I met him. AC with the KRC unit uses stock coyote compressor, biggest challenge is nobody makes an adapter for lines yet that I know of and so you have to find stock lines and weld ends on
I looked at that set up Peter. The advantage of the ford system is I could run a stock ford pump making power steering lines easier but I kinda want ac in this truck. I don't have ps or ac or defrost in my street rod so I'm the only one who drives that, and would like my wife and daughter to drive this one too.
I really like your falcon, if I could have found a 63 I would have built that back in the 80s instead of all the mustangs, Are you running a KRC pump?
Bryce
12-10-2013, 07:40 AM
I have a KRC pump now. My first test drive was last Sunday.
48prerunner
03-24-2016, 01:02 PM
I went with the KRC set up I'm very happy with it so far even ended up running a hydroboost out of a 2004 super duty. I got the reserve used from a nascar car.
