View Full Version : Pedals and rear under floor master cylinder/clutch resorvoir
badbrad900rr
12-08-2013, 06:49 PM
I'm working on my floors in my nova it's a full frame car now and I'm trying to keep the firewall slick and clean. I want to mount the master cylinder and clutch resorvoir out of sight under the floor with a access door. My question is what pedal set up and master cylinder configuration do I need to use. The car has wilwood 14's 6 pistons on the front and 12.5s 4 piston on the rear. I have looked for hours but can't make sense of what I need. All help is appreciated.
and the frames not in the way? I know the frames in the way of proper pedal placement in my 1968 camaro
badbrad900rr
12-09-2013, 07:22 PM
No it's a custom frame and the firewall has been moved back 8 inches
Heleanor
12-10-2013, 05:27 AM
Why not look into the Kugel components under dash setup? That is what I put in my 66 to clean up the firewall.
Regards,
Mark
badbrad900rr
12-10-2013, 08:04 PM
Thanks for the info Mark. I will look into that.
