View Full Version : G-body C5/C6 rear disc conversion - KORE3 kit
83hurstguy
12-07-2013, 09:38 PM
I recently finished converting my G-body with 8.5” 10 bolt to C5/C6 brakes, using a KORE3 kit with parking brake. This was not a bolt-on kit, but thanks to a ton of help from Tobin and some friends, we made it work. I figured I’d post this project up to describe the “why” and “how” for anybody else interested. My rear end was already converted to 30 spline Moser axles (still with C-clips), so I needed a brake kit compatible with that.
I considered the G-body rear disc swap options, and settled on modifying an A-body KORE3 kit with parking brake for several reasons. The LS1 rear disc swap is popular, but the downsides include shock relocation and potential contact between the caliper and frame on severely lowered cars. The C5/C6 rear rotor is shallower, so the caliper sits farther outboard. Coupled with the clocking being lower on the axle (3 or 9 o’clock), packaging is improved over the LS1 swap. The Baer rear disc conversion is nice, but the corresponding Track4 front brakes need more wheel clearance than the C5/C6 front brakes. I’m using 17” Billet Specialties Street Lite wheels (at least for now), so wheel clearance was critical in my selection. Lastly, converting to a Corvette-based brake setup allows for various rotor sizes and aftermarket rotor/caliper options for potential future upgrades.
The KORE3 kit utilized for the project is located here: http://www.kore3.com/proddetail.php?prod=10277-01
This project actually started when I got a great deal on a lightly used set of KORE3 caliper brackets and parking brake plates from a friend who put the Ford ends on his 12 bolt. I bought brand new C5 rear calipers, DBA4000 rotors, hoses and miscellaneous parts from Tobin to complete the kit.
G-bodies have the same axle housing flange as a 3rd gen F-body, so the first step is to convert the flange to a GM standard 4 bolt pattern. There is plenty of information out there on how to do this, so I’m not going to regurgitate it here. The thirdgen.org site has a descriptive set of instructions for this process: http://www.thirdgen.org/ls1reardisc
The only step I added was to have a local machine shop turn an aluminum spacer to fit between the axle tube outer diameter and the caliper bracket inner diameter for use while drilling the new housing flange pattern. This ensured the holes would be in the right spot. Overkill, but I tend to be cautious. Here’s a picture of the spacer…
86825
Here’s the critical attribute for why the KORE3 kit is not a bolt on to a G-body. The KORE3 kits are designed for a rear end housing flange to axle flange offset of either 2.75” or 2.81”. G-body offsets tend to be less than that, but can vary based on how the carrier ends up shimmed in the rear end housing. My offsets were 2.77” and 2.68”. This does not only affect the parking brake engagement, but also affects how the caliper abutments are centered over the rotor. Here’s a picture that illustrates how the kit lines up when mounted. It’s hard to see the exact details, but you do not have a ton of tolerance in the caliper abutment to be off by 0.060” or more.
86824
With assistance from Tobin for stress analysis, we decided to mill pockets in the caliper brackets to center the abutments over the rotor. The axle side with the short offset ended up being thinned to 0.1875” where it attached to the housing end (with Tobin’s okay). With bracket being bolted to the housing end, you essentially have a composite member at that location. Here are some pictures of the milling process and the brackets after replating. (as a side note, the brackets I got used were for the 2.81" offset design, so they are 5/16" thick... hence why the milling looks so deep. If starting with a 1/4" bracket from KORE3 for the 2.75" offset, there wouldn't have been so much material removal).
868238682286821
I also had the axle flanges turned down to 5.875” diameter with a 1/8” x 45* chamfer on the edge, and ARP studs added. The turning wasn’t necessary for the DBA rotors I utilized, but other rotors may not fit in the future. I also had the calipers powder coated by Mike at thepowdercoater.com (great customer service and results).
Did a final mockup of everything before painting the rear end, including routing the brake lines.
86820
The rest of the assembly process is standard working through the KORE3 supplied instructions.
868188681986826
Here’s a picture of the frame rail clearance to the caliper at full bump travel:
86828
Here’s a picture of shock clearance:
86827
The project met all my goals: having a parking brake, requiring no shock relocation and having no interference with the stock rear frame rails at full suspension compression. I also deleted the factory combination valve to use adjustable proportioning to the rear brakes; I’ll discuss that process separately. The design of this KORE3 kit is impressive, and Tobin's knowledge and customer service were integral to completing this project.
If I had to consider doing this again, I would see if Moser could supply a custom length C-clip axle (0.070” longer) rather than go through the milling process. The key is to check axle offset before ordering parts and develop your plan accordingly. As another alternative, if you convert the 10 bolt to Ford ends, the axle offset is easily controlled and you can use a different KORE3 kit.
To clear the 17” Street Lite wheels, I ended up using a 3/16” spacer on the rear wheels, and a 5/16” spacer on the front. The rear only really needed a 1/8” spacer, but nobody makes a decent spacer (center piloting) in that thickness.
By now, you probably think I'm nuts, but that pretty much wraps it up. I have the parking brake cables routed (Lokar) but not tied in yet. I will update this once I complete the parking brake connection in a few weeks.
carguykeith
12-08-2013, 02:44 AM
Great write up! I really battled my rear disk setup plans but couldn't get a warm and fuzzy with any of the stock setups with regards to pad knock-back. You're running stock rear wheel bearings right? What did Tobin say about knock-back and diff fluid leakage? I gave up a parking break for my setup which will really be an issue when I loose the auto, but figured I could get by with a mechanical caliper when I finally do.
SSLance
12-08-2013, 05:59 AM
Nice write up Luke, good work! Final product looks great.
In Hot Rodding, it's handy to have a machinist available to help make parts fit right on your application...isn't it?
83hurstguy
12-08-2013, 06:50 PM
Thanks! Stock rear wheel bearings. Provided you have the end play under control, knock back shouldn't be a huge deal. I have my end play less than 0.009" by using thicker C-clips... having a new posi unit helped with that. I talked to Tom's differentials and he recommended not having less than 0.005" end play to prevent thermal growth from locking up the limited slip and inducing clutch chatter. I'm going to have to keep an eye on wear over time, as that end play will tend to increase. In regards to leaks, I've been pretty lucky with axle seals. However, I put in new Timken seals and had an immediate leak when I filled the diff. Put in another new seal, and it's dry again. A friend who converted to the Ford ends had a leakage issue on his too, so I'm not sure you can guarantee a win either way.
I did contemplate not using a parking brake for a while (or a mechanical option as you mentioned), as that would have been much easier to do. I decided to try going all out first and see how it turned out. Of course, you can also get brackets from flynbye to use an LT1 camaro rear caliper with integrated parking brake, but I wanted the calipers to be a better match front and rear.
Thanks Lance! Unfortunately I hadn't met you and John when I started this project or it would have been easier! Unfortunately, I got to find out which machine shops I don't want to deal with again, haha... having a machinist you can work with is pretty much invaluable.
carguykeith
12-11-2013, 01:57 AM
Sounds like you have a god handle on it but if for some reason you end up wanting a different solution later on and can go without an integrated parking brake I'm really happy with my setup.
83hurstguy
12-12-2013, 07:53 PM
I may have spoken too soon. Have an axle seal leak... the second time this has happened (I figured the first was a fluke). The Timken seal is leaking between the rubber lip on the axle. Changing brands, we'll see what happens. What a huge pain to fix.
SSLance
12-13-2013, 05:11 AM
I've been dealing with axle seal leaks ever since I put the QP 9" in my car. After a while you learn to like the smell of gear oil. #notreally
I think I finally have a plan to stop mine for good next time I pull mine apart, we'll see. Good luck with yours.
83hurstguy
12-13-2013, 06:54 AM
Friend who just converted to 9" ends with SET 20 bearings had a similar issue. He used the toyota FIPG (form in place gasket) around the perimeter of the seal and it's been holding up (so far).
Unfortunately, I'm not sure what I can do on mine other than go back to chicago rawhide seals that were USA made.
SSLance
12-13-2013, 06:58 AM
Not sure what gear oil you are running, but if synthetic...a lot of people have gone back to running regular old 75W90 dino based gear oil to stop the axle seal leaks. Synthetic gear oil will find it's way past just about any seal.
83hurstguy
12-13-2013, 08:12 AM
Yeah I'm on 80W-90 Torco Racing Gear Oil, dino oil. Almost went to the 85W-140...
12-13-2013, 10:26 PM
Nice detailed write up.
Question for you Luke,
With the modification was it difficult to assemble the parking brakes and get the axle in far enough to get the C clips put in? What was the sequence that you used?
83hurstguy
12-15-2013, 01:47 PM
Thanks, and good question. KORE3's design allows the parking brake backing plate to be loosened and slide towards the center of the rear end to make C-clip installation easier. You loosen the nuts on the parking brake backing plate, twist and push it towards the center of the car, install the axle, pull the backing plate back out, twist it and tighten the nuts. Hard to explain with out pictures, but it's a neat design. Very easy to install the axles.
carguykeith
12-19-2013, 08:56 PM
I hope you get the leak figured out, I had high hopes this might be a solution for g-body rear disk with parking brake.
If I were to do it all again I'd probably just go with a Speedway floater 9", I know my 8.5 is strong enough for anything that I'll throw at it but the parts availability for the 9" would put you way ahead and I bet for not much more $ even if you already had the 8.5 housing.
83hurstguy
12-20-2013, 12:59 PM
I bought an LPW cover along with some CR brand seals... should have it done by next week sometime. I'd like to put miles immediately on it to help break everything in, but ice and snow isn't going to let that happen.
Agree with your second statement... I'm less than $1k short of a floater for what I have in my rear axle assembly. Unbelievable...
Number1
08-04-2014, 06:28 PM
Any updates on how the brake system is working? Also did you fix the leaks?
83hurstguy
08-05-2014, 07:00 AM
Brakes work great so far. No complaints... I haven't gone out and really pushed the car hard yet either, just a lot of street driving. Pedal feels slightly lower than it used to be, a 1" master cylinder would probably be a touch better, but I'm not going to change it. There's a bit of pad squeal at light braking when coming up to a stop, I'm going to have to put some anti-squeal on the back of the pads. Surprised the hawk pads are making noise.
The CR seals fixed my axle leaks so far, knock on wood... now that I say that, I'll probably get home tonight and see a drip inside a wheel...
Number1
08-05-2014, 07:33 AM
What wheels do you have on your car?
83hurstguy
08-05-2014, 01:11 PM
Billet Specialties Street Lites, 17". Required a spacer front and rear for the brakes.
