cbramey
12-05-2013, 11:15 AM
Will go on ebay soon, or barrett perhaps if not sold first. Asking $69,500, and when you see this car that's a steal. That's not even 2/3 of the cost of present parts, much less labor, development, or parts that didnt cut it. Car is west of Houston, Texas.
https://static1.pt-content.com/images/pt/2013/12/_57JPG-1.jpg
INTRODUCTION:
This car is a unique and superior example of one of the industry’s finest vehicles, the Superformance Mk III Cobra, SPF1021.
This car has been professionally engineered and improved from its original Superformance design over the last 8 years by a multi time SCCA National Champion, and unlike most any other Cobra you will ever see, it feels, runs, drives and handles as good as it looks, and like the supercar it should be. No expense has been spared, and you’ll never see a better Cobra.
First the high points, with more details below:
https://static1.pt-content.com/images/pt/2013/12/_57JPG-2.jpg
MKIII CHASSIS:
It begins with the outstanding Mk III factory built rolling chassis:
http://www.superformance.com/mkIII.aspx (http://www.superformance.com/mkIII.aspx)
The Superformance MKIII is the only Cobra replica built under license from Carroll Shelby Licensing Inc.
The Mk III starts with four wheel unequal length double A-Arm independent suspension, and this one also comes with a custom supercar Woodward MRC power steering system and custom tuned suspension, professionally engineered for proper feel and handling. (this is the anodized steering system in use on F1 cars, Bugatti’s, etc.).
http://www.woodwardsteering.com/index.php?option=com_content&view=article&id=682&Itemid=586 (http://www.woodwardsteering.com/index.php?option=com_content&view=article&id=682&Itemid=586)
This unique car also comes with custom engineered Wilwood Pro Spindles and 4 wheel disc brake system with dual master cylinders. This provides improved camber curves, roll centers, less bump steer for much better handling, as well as easily adjustable brake bias for the best braking and utmost safety in any environment.
This unique car also weighs in well UNDER 2350 lbs with all fluids and 5 gallons of gas. Of that 2340 lbs, 53.4% of the weight is on the REAR wheels for perfect weight distribution and tremendous traction.
https://static1.pt-content.com/images/pt/2013/12/_57JPG-3.jpg
ALL ALUMINUM 427ci FORD FACTORY SMALL BLOCK:
It is powered by an ALL ALUMNINUM (block and heads) Ford Racing Engines factory-hand-built, 600 horsepower, 427 cubic inch Windsor small block engine that weighs only 350 pounds. This entire car, with its perfect gearing, independent suspension and differential, and 600 horsepower. Very few people on the planet have ever driven anything as fast as this car… yet due to its massive tires, superior rear suspension, and outstanding weight distribution, this car hooks the power up and puts it down extremely well, and can be as docile a cruiser as you could want until you really get into it.
This body on this car is clean and sleek, with extra hood clearance for better power and efficiency, shaved fender wells and full underbody exhaust for a sleeker look, (no sidepipes), and custom interior with MOAL electronic gauges and mil-spec switches. The body is decked out with fantastic Lamborghini Titanium paint (no stripes) from Superformance that absolutely outshines anything I’ve ever seen in the sunlight or at night.
https://static1.pt-content.com/images/pt/2013/12/_57JPG-4.jpg
HISTORY:
For the seller, this car gets duty driving to nice restaurants and car shows, cruising on nice days, and an occasional autocross. Even on street tires, it is faster in an autocross than the owner’s national SCCA winning Z06. This car has not otherwise been tracked or drag raced, except twice at the drag strip to confirm its power and reliability on track (unbelievable performance). Valets will want you to park it yourself, and leave it up front of any hotel or restaurant. Mechanics will drool over it at gas stations. Car enthusiasts will line up to ride in an autocross. Whole Harley clubs will surround you on the highway and look you over, grinning with thumbs up. Cops will pull you over just to talk to you about it, and let you go with a grin. This car has charisma like no other, and performance to match. It is clean titled, and has been insured, registered, and emissions exempt in Harris and Ft. Bend County, Texas, as well as in Kansas City. No issues with registration or emissions. This car has 2400 miles on it. (In the signature action photo of this ad, the car was at an autocross, going over 60 mph, pulling over 1.2 g’s cornering on street tires, and putting a grin you can’t believe behind that helmet!).
THE DETAILS:
CHASSIS:
Jig-Welded parallel ladder frame of heavy wall 2" x 4" rectangular steel tubing with large diameter outriggers. Frame incorporates front and rear crumple zones. Door hinge, steering column and windshield pickup-points incorporated onto main chassis. Ford aluminum housing 8.8 independent Limited slip differential with heavy duty axles, u joints and cv joints.
BODY:
Show quality two-stage paint finish in Lamborghini Titanium. Hand laminated fiberglass body with reinforcing inserts. Hand laid fiberglass panels with steel tube reinforcements in all openings. Where the body points carry loads they are reinforced with steel bars or panels. Body bonded to chassis and is completely non-stressed. Beautiful Lamborghini Titanium paint (no stripes) from Superformance, with extra hood clearance, shaved fender wells for a sleeker look, underbody exhaust (no sidepipes), and 3M paint protection film in key places to prevent chips or wear on the paint. Monza style aluminum gas filler. (locking gas cap). Stainless steel roll bar, chassis mounted (currently out of car for a sleeker look, but comes with car and is easily bolted in. In fact, the original wood wheel, chrome bumpers, shifter, gauges, etc., all come with the car if you wanted an ‘original’ looking cobra.
FACTORY HARD TOP:
Factory Optional Superformance hard top, painted in body color, and containing real glass and molded weatherstrip is included (this is a $4,000 option).
https://static1.pt-content.com/images/pt/2013/12/_57JPG-5.jpg
SUSPENSION AND BRAKES:
Wilwood brakes, 1.19 x 12.19 rotors front, 4 Piston Dynalite Pro Calipers front and rear. Olthoff braided stainless brake lines. These brakes are a major upgrade from original Superformance brakes.
Tilton hydraulic clutch and dual adjustable front and rear Brake master cylinders with custom Tilton aluminum pedal assembly for improved reliability, safety, looks, and ergonomics. These pedals fit and travel perfectly, unlike the original Superformance ‘factory style’ units, and also save a bunch of weight.
Four wheel unequal length double A-Arm independent suspension, and this car has Custom crafted Bilstein coil-over shocks with custom tuned Hypercoil springs.
This car also comes with a custom supercar Woodward MRC power steering system and custom tuned suspension, professionally engineered for proper feel and handling. If you want to park this car, work a drive through, or autocross it (or track it), the faster ratio, perfectly weighted steering, and improved bump steer really sets this unique car apart.
COOLING, WIRING AND GENERAL:
Latest technology single row high performance aluminum core radiator with shroud and 2 electric fans; oil cooler; hand fabricated stainless steel engine louvers; original style wiper assembly with 2 speeds and 140 degree wiper arc; hand fabricated windshield assembly to original specification, chrome plated. Oil cooler, remote oil filter, and braided lines. Even with 600 horsepower, this car runs at 180 degrees even stopped in Texas traffic in the sun on 105 degree days, and this car has never gotten above 190 degrees.
INTRUMENTATION/CONTROLS:
Custom Classic Industries MOAL electronic gauges (original mechanical Smiths gauges included), with milspec toggle switches for lights, fans, etc. This Car was fully professionally rewired to upgrade the harness for reliability and longevity, and includes proper relays, grommets, kill switch, and fittings. All wiring professionally routed, soldered, heat shrunk for water proof connections, and loomed. Hand crafted shifter and handbrake. Extra bright Halogen and LED headlights, turn signals and brake lights. (The Factory Superformance wiring was not heat shrink protected and lacked appropriate gauge wiring and relays for a proper fuel pump, etc.).
https://static1.pt-content.com/images/pt/2013/12/_57JPG-6.jpg
INTERIOR:
Comfortable and supportive hand made seats upholstered in German specification automotive leather. These seats, unlike most replica cobra’s I’ve driven, are REALLY comfortable and supportive,you’re your seating position is also comfortable and proper. This is really rare in replicas. Disclaimer, if you are a huge guy, these cars are not for you: however, this one has more leg and foot room than a normal Superformance car due to the new pedals and lowered seats. Fully carpeted floor, center console, sides and rear firewall. Carpeted interior and trunk. Aluminum finished firewall. Wipers & Washer. Leather seats. New Race Quality Quick Release Harness seat belts. Custom Black Alacantra Race steering wheel and shifter boot, with AC lables.
DIMENSIONS and CAPACITIES:
Wheelbase: 90"
Length: 152"
Height (Top of screen): 48"
Width (Overall): 69"
Track Front: 54"
Track Rear: 57"
Weight 2340, 53.4% rear weight distribution
Fuel Tank: 17 gal.
CCW ultralite Classic 18 inch wheels, 10” wide front, 12” rear
N555-R Tires-Front 285/35 R18, Tires-Rear 335/30 R18
Ford Aluminum Block M-6007-Z427AFT Windsor Engine: 7 liter, 600 hp, 350 lbs.
Tremec 31 spline heavy duty 5 speed manual overdrive transmission
Tilton Hydraulic clutch and aluminum flywheel.
ZF Limited slip differential. Ratio 3:45:1
ENGINE AND ACCESSORIES:
Ford Aluminum Block M-6007-Z427AFT 600 horsepower Windsor engine
http://fordracingparts.com/m/Part.asp?p=12378 (http://fordracingparts.com/m/Part.asp?p=12378)
Built on Ford Racing's stout aluminum Z351 block, the FRPP 427 crate engine is engineered and built for drive-ability and durability while still offering a throaty growl. The Ford Racing 427 crate engine is ideal for street rods, kit cars and all Ford projects requiring big power in a reliable, lightweight package.
Based on the low volume and high quality, I believe this motor will ultimately be a collector’s motor from Ford. This motor was professionally tuned on a chassis dyno in the car. Fully warmed up, just as you would drive it on a summer day, it made 549 rwhp on the chassis dyno at 6400 rpm, and made over 500 at the wheels from under 5000 all the way to 7000 rpm -- and was still making great power at our rev limiter (7000 rpm).…. The motor made over 400 foot pounds of torque from 2500 rpm all the way to 7000 (peak at 485). By comparison a stock LS7 motor in a Z06 made 442 rwhp on the same day, and that car has taller gearing and another 1000 pounds of weight to drag around. This car has a power to weight ratio of 3.91 lb/hp; compared to 5.33 for the ZR1, and 6.34 for a Z06. In other words, you’ll leave those modern supercars in the dust.
Most Cobra replicas do not run like people hope, because it is so hard to put proper fuel delivery, proper exhaust, and proper intakes on these cars with enough hood clearance to make the advertised power. Most “600 horsepower” Cobra replicas, in fact almost ALL of them I have driven, THINK they have 600 horses, but actually make under 300 due to these problems. NOT THIS CAR. THIS CAR IS SORTED AND FAST.
427 cubic inches
600 hp @ 6500 rpm (STP), 558 lb-ft @ 5000 rpm (STP)
570 hp @ 6500 rpm (SAE), 530 lb-ft @ 5000 rpm (SAE)
Each 427 Aluminum Crate Engine built is dyno tested
11.0:1 compression ratio (nominal)
Ford Racing aluminum 4-bolt main block M-6010-Z351
Forged Mahle pistons
Forged steel H-beam connecting rods
Forged steel crankshaft
Solid Roller Cam
Intake duration 258 @ .050" intake
Exhaust duration 260 @ .050" exhaust
Valve lift intake .644"
Valve lift exhaust .653"
Roller Rocker Arms (1.65:1 ratio)
Rocker arm stud girdle
Double Roller Timing Chain M-6268-B302
High performance front sump oil pan
SFI Approved high performance harmonic balancer
Internally Balanced
CNC ported Ford Racing aluminum "Z" cylinder heads M-6049-Z304P with 2.08"intake valves and 1.60" exhaust valves (these heads are reported to flow 320 cfm intake and 230 exhaust – with great velocity).
Additional Accessories:
MSD custom billet distributor #85840, modern vibration damped MSD 6 AL Ignition Module, MSD Vibration proof coil and MSD plug wires and loom.
Edelbrock intake manifold #2924
Carburetor, Holley full Billet aluminum Ultra HP 80803HB, 750 CFM, with jet extensions, road race floats, High Flow Needles and Seats, http://www.holley.com/0-80803HB.asp (http://www.holley.com/0-80803HB.asp)
Stainless steel fuel tank. 17 gal. (Pressure tested.)
Aeromotive Fuel Pump, AM-18688, 340 stealth unit with an in tank pump suitable for carburation or EFI, with a 13201 carbureted regulator, 40 and 140 micron anodized filters, and dual Braided Kevlar (Formula 1 fuel line) 8 – AN fuel feed and return lines with all aeroquip fittings.
http://aeromotiveinc.com/products-page/stealth-fuel-systems/18688-phantom-340-stealth-fuel-system/ (http://aeromotiveinc.com/products-page/stealth-fuel-systems/18688-phantom-340-stealth-fuel-system/)
Custom fabricated Dawson ceramic coated 1 7/8” primary Tri – Y under body headers, with 3.5” oval tubing and Flowmaster 40 series underbody exhaust.
All of the parts and labor presently in the car are either brand new (like the fuel ignition systems), or 2 years old (the wiring, motor, trans, etc.). All of the parts on the car have been vetted, tested, and improved over time. I have been through many intakes, carbs, fuel systems, ignition systems, suspension settings, brake parts, etc., and thousands of development hours to get the car to this point, and have stacks of parts that were not quite good enough over the 8 years of development in this car.
Just the current parts combination alone, without the development, and without the discarded parts, cost over $100,000.00.
INTRODUCTION:
MKIII CHASSIS:
HISTORY:
THE DETAILS:
CHASSIS:
BODY:
FACTORY HARD TOP:
INTERIOR:
Wheelbase: 90"
Length: 152"
Track Front: 54"
Track Rear: 57"
Fuel Tank: 17 gal.
427 cubic inches
Solid Roller Cam
Internally Balanced
