View Full Version : 1965 amc rambler american 220 2dr.
greg9705
12-04-2013, 10:06 PM
here are a few photos of my 65 rambler american from when i brought it home about 4 years ago. This was an all original california daily driver that has made it home to its birth town of kenosha, wi. i have a quite a few photos of the progress of this car that i will upload when time allows. i have been working on this for the past three winters and have been successful at keeping it on the road in the summer.
like it!!
more AMC cars are needed here!
snopro
12-05-2013, 06:25 PM
This is exciting, I have a 64 rambler almost the exact same just seafoam green lol. I will be starting that project once my truck is closer to complete. Im subscribing and looking froward to the updates
chris
rjsjea
12-05-2013, 06:53 PM
Clean little AMC
greg9705
12-05-2013, 08:20 PM
this is the first of motors to be put in the rambler. the motor is a amc 360 that i pulled from a very rusty 1974 amc hornet hatchback. i pulled the entire drivetrain out of the hornet to swap into the rambler. behind the motor is a torque flight 727 that i had rebuilt with heavy duty clutches upgraded planetary and a reverse manual valve body with a 2500 stall converter. all this put power to a amc 20 rear axle with a factory posi and 3.54 gears. the motor was rebuilt before i got the hornet and was parked next to someones garage for about ten years before i found it. the bottom end was built to stock specs. the heads were ported and had an edelbrock performer rpm intake and a mild crower cam. this combo was good for 350 hp and 375 ft. lbs. torque. i pulled the engine crossmember from the hornet and bolted it into the rambler like it was made for it. that is what makes amc's so awesome, the fact that so much is interchangeable between all the different models they built through the years. the only major mods i had to do was to massage the trans tunnel a little for the huge trans and some cutting and welding to the factory rambler trans crossmember the rear end also bolted right onto the ramblers stock leaf springs.
neongreen
12-05-2013, 09:30 PM
Very cool! lets see more!
77tony
12-05-2013, 09:47 PM
Neato :bananna2: T
Munssey
12-05-2013, 10:13 PM
X2! Love the lines on those cars. SO classic 60s.
RMMiller
12-06-2013, 05:50 PM
Man what a clean car! Perfect platform for a build too, no big uglies to deal with.
Bill Howell
12-06-2013, 06:02 PM
Subscribed. I love these 60s Americans
Hornet LSX
12-06-2013, 08:24 PM
At first I thought it was going to a complete restoration which was an excellent plan. but now a V8 transplant! restomod on!! love it. will be following along.
BTW, I don't know if it's considered taboo to plug an alternative suspension supplier here but here goes. Check out Control Freaks complete IFS and rear 4 link suspension kits for ALL amc's! look a FREAK RIDE.com reall BA stuff for AMC's Fords and especially Mopars. They also make headers and really trick aluminum radiators for AMC's as well.
My Hornet is running their complete IFS and rear 4 link set up as well as the sub frame connectors. The handling is absolutely amazing now.
therobski
12-14-2013, 04:03 PM
Hey U AMC guys, My Uncle Roland Hill passed away at 90 two years ago in Kenosha, he was the Plant Manager! He went around from the Lake Shore plant to others on 60th and the body Plant in Milwaukee. He was the dog all the way back to the 40's on up. He drove the "bath tub" Nash Ambassador when I was knee high.
greg9705
12-15-2013, 09:55 AM
here are some photos of the freak ride triangulated 4-link kit with double adjustable coilovers. i decided to order this kit immediatly after driving this car for the first time after installing the 360 and automatic trans. this car had so much axle rap with the stock leaf springs that the yoke on the rear diff came up and hit the floor. after installing this kit the handling was almost unbelievable and the ride is nothing short of amazing.872088720787206
dodgedartgt
12-15-2013, 10:09 AM
Subscribed
Nice car, I've always liked the Ramblers. I didn't know how much interchangability there was from one body to the next. My F-n-L drove a J20 truck he bought new in '74. Along the way, he picked up a 360 or 390 long block as a spare rebuilder. I inherited it after he passed away, and got an AMC 727 from a buddy's brother for $20. I was just looking for the "right" body to drop it in. Ended up moving to FL before that ever happened... darn.
We need pics of the Freaks 4-link set-up, not just of the loose pieces. I've been looking at there site and considering them for my '67 Barracuda.
Mike in FL
greg9705
12-15-2013, 04:54 PM
here are some photos of the 4-link installed in the car along with the subframe connectors also from freak ride. everything fit like it was meant to, just takes a lot of measuring. all of this work has been done without a hoist. 872418724287243
greg9705
12-15-2013, 05:32 PM
these next photos are the tremec tko 500 that i sourced from a 1989 mustang gt 5.0 that i found on craigslist. this trans has the smaller input shaft out of the tko-500 line of transmissions. this is mated to a 6.5" deep 1982 jeep cj bellhousing. the flywheel is from hayes and it is for a 1966-69 amc v-8. and it uses a clutch from 77 JEEP CJ with a v-8. the trans mounting holes on the bellhousing had to be relocated to fit the tko-500 to it. i am also running a 3/4" slave cylinder from novak adapters for a jeep bellhousing and 3/4" bore master cylinder from wilwood. i also had to modify the trans tunnel quite a bit as this trans is really tall be based on the old ford toploader. 87244872458724687247872488724987250
snopro
02-26-2014, 05:28 PM
looking great, how are you liking all the updates? Whats next on the list?
Chris
Mach Par
02-26-2014, 07:04 PM
I LOVE AMCs. If they weren't so hard to find around here I would have a 71 Javelin.
Auto Rod Technologies
Nice car!!! Need more of these in here.
greg9705
02-24-2016, 11:50 AM
It has been awhile since posting here but i am going to have some more updates on the car.
Sno-pro i am very pleased with the updates so far. Sorry it has taken a long time to respond.
therobski
02-25-2016, 02:49 PM
X2 anxious for the updates, what a great car to work with!
75gremlin
02-25-2016, 02:59 PM
I want that thing. I too am anxious to see where you go with the build.
greg9705
08-16-2018, 09:19 PM
Its been a while again but i bought a new house since i last posted and have been really busy. I did get to redo the front suspension since my last update. Added an upper control arm and qa1 coilovers to the front. Another forum member on here has designed a suspension upgrade for the small body rambler to replace the trunions with some arms and coil overs with some adjustability. Major improvement over stock and very reasonably priced.155644155645155646155647
Zspoiler
08-17-2018, 11:34 AM
Another Rambling Rambler..Maybe have a set of widened stock wheel with hub caps. And it would be a good "sleeper" .And most people wouldn`t know what it is.
greg9705
08-21-2018, 05:40 PM
Another Rambling Rambler..Maybe have a set of widened stock wheel with hub caps. And it would be a good "sleeper" .And most people wouldn`t know what it is.Here it is with a stock type steel wheel and dog dish hubcaps155795
Zspoiler
08-22-2018, 05:28 AM
Ah sleepers.
813Demon340
08-24-2018, 09:30 PM
Glad to see another one of Mikes/ 343sharpstick kits being used on here! Lover your Rambler, want are your future plans with it?
nothing sleeper about the Rambler i built, keep us updated!
155868
greg9705
08-25-2018, 06:30 AM
155868I love it, that looks awesome.
mike343sharpstick
08-27-2018, 07:43 AM
Greg has one of the first few kits, great to hear an update! He did real well at an autocross late last summer, we had two AMC's at that event, what a great time.
Hope your are getting lots of spirited driving fun with that front suspension. Are your going to the Auto-cross at Road America again next month? Registration just opened up for that event.
Cheers
Mike
greg9705
08-27-2018, 08:07 AM
Cheers
MikeYes Mike i would definatly like to go to that event again i had a lot of fun. I will see about getting signed up again. See you there.
Greg
mike343sharpstick
09-06-2018, 05:59 AM
Greg, I came by this screen shot today showing the CAM results from the autoX last year. Hope to see you there.
156261
greg9705
09-06-2018, 09:04 PM
Hi Mike. Im all registered for the fvscc event. Looking forward to it again. See you there.
Greg
Boosted Falcon
09-09-2018, 04:20 AM
Mike/Rod your Rambler builds make me smile. Rod I saw your car again this last weekend at NCM Motorsports Park/LS Fest, always nice to see something really different.
InRogue
10-01-2018, 06:38 PM
157028Nice ride Greg. Here's my '66, hoping to do the same thing. Eric
greg9705
10-01-2018, 07:15 PM
157028Nice ride Greg. Here's my '66, hoping to do the same thing. EricNice looking ride Eric. Its nice to see more of these cars getting out there. Mike did a nice job with the front suspension. It works really well and has lots of adjustability. He is also working on a lower control arm setup that has better movement and eliminate that strut rod and bushing that can bolf into the cars. I was with Mike at an autocross event at Road America last weekend. It was a lot of fun to get the cars out on the track.
