View Full Version : adjustment of pinion
RamAir
12-03-2013, 02:02 PM
So, i have replaced the posi unit in my GM 8.5" axel. I am trying to figure out if this pattern is ok. If not, what changes should I do? The backlash is set to 0.008" per Richmonds spec.
Heleanor
12-03-2013, 05:43 PM
It is a little off center to the toe side. I would add .008" shim to the pinion to move the pattern closer to the center and mark it again. If it was a high horsepower drag car it would be ok as the flex would center the pattern but for a street car you want to get it a little closer to the center of the ring gear.
Hope this helps!
Mark.
RNation0001
12-05-2013, 01:26 AM
what he said lol,
RNation0001
12-05-2013, 01:29 AM
if you look at my thread on my rear end rebuild theres a picture of a pattern thats more in the center.
aikan50
12-10-2013, 08:53 PM
what a great work.
badazz81z28
12-11-2013, 02:40 PM
I know when I did mine, a lot of trial and error. I kept adding and taking away until I got it close as possible to the reference pictures. Its very important that you setting up as if it was for real (Minus crush washers, and press fit in shims) and rotating it with some load by the axle to get your marking.
http://www.explorerforum.com/forums/showthread.php?t=144780
Dallon666
12-16-2013, 02:41 AM
I dunno if we'd really be able to see something as organized as people getting a food stamp debit card from their local church though..
RamAir
12-19-2013, 02:25 PM
Thanks for all input. I think it is good enough, it is not simple first time you are doing it. Next time it will go much faster.
Heleanor
12-21-2013, 04:40 PM
You are showing the coast side in the above picture but if the drive side is close to the same pattern you will be ok. Remember when you hit it hard the pinion will try and push away from the ring bringing the pattern closer to the toe.
