jovozx12
12-01-2013, 12:52 PM
Cleaning out the garage and have many LS parts for sale. Located in Las Vegas, NV
LS1 motor out of a 2000 corvette. It appears to be low mileage. Comes just as pictured with intake (not an LS6). Has a DBW throttle body. No injectors or fuel rails. Heads are 853s $1600 Sold
LS1 853 Casting Heads. Come with stock valves and valve springs. $100
LS Rocker Stands. Will fit all LS based engines except for the LS3/LS7 type heads. $25 for the pair.
LS1 5.7L Pistons and rods. I only have 7 pistons and 7 rods. $75
LS1 F-Body Balancer. $40
LS1/LS6/LS2 Valve covers with bolts. $50
LS2 Oil Pump. This should fit any LS style motor. I pulled this out of an LS2 that was in a CTSV with 73k on it. $30
LS Pushrods Stock Length 7.4 These are stock. I have 2 sets. $20 per set.
LS Chromoly Pushrods 7.550 .080 by Texas Speed $80
LS1 Valley Cover. $30
LS1 Rear Cover. $30
Cloyes timing set. this a double roller set for a gen III motor with a 3 bolt cam. It is brand new however the machine shop lost the crank sprocket so all i have is the chain and the cam sprocket. Part #9-3159 $30
LS1/2/6 16 Stock Rockers. The trunions have been removed and are ready for the comp trunion upgrade. $45
LS 3 bolt DBW throttle body with sensors. part # 25317951 $60 Sold
MAF stock 78mm 3 pin plug. $40
LS1 Steam tube. may have to be messaged a little back into shape. $25
C5/C6 Front and Rear Brake calipers and Abutment brackets. $400 Sold
BMW 3 series seats. All power and easy to hook up 2 wire install. $300
Jerry 712-253-7583
LS1 Rear Cover. $30
Jerry 712-253-7583
