View Full Version : electric fans versus flex fans or stock fan in an 68 camaro
jesse4868
11-29-2013, 01:08 AM
hi my name i jesse i new to this site, i have a 68 camaro with zz4 with the serpentin kit from gm, i am not sure in keeping the stock radiator with a flex fan that i have, or changing to aluminum radiator with 2 electric fans, any body has any suggestions?
chevnut55
11-29-2013, 07:12 AM
I had a Camaro flex fan break in tuning and go into my chest and almost kill me for one.
Its cheap now to pick up a aluminum rad that bolts in and a aftermarket or junkyard fan with a aftermarket harness.
It will not rob any HP and will run cooler.
birdsandbowties
11-29-2013, 10:09 AM
i have pair of fans on my 94 x-cab gmc from a 97 z28, i only have one fan running on a ground switch, i bought a 160 degree ground switch that screws in the side of the head on the pass side and also used a 4 prong relay, my truck with the stock new radiator runs 120-130 all the time, very seldon gets over 130 even sitting in traffic, i am with chevnut,,,,the stock and aluminum fans suck and if your not carefull you could be missing a limb from one of those things, i havent had a stock fan on a car or truck in 20 years !! always been electric
BMR Sales
12-03-2013, 06:59 AM
Welcome Jesse!
welcome to the site, I will jump in and say use an electric fan, easier to work around and safer
BonzoHansen
12-03-2013, 12:02 PM
flex fans are junk. that is why they come with cool stickers:
https://static1.pt-content.com/images/pt/2013/12/FlexFanWarning-1.jpg
the other note is if you go stock style clutch fan, you need one that works with the reverse rotation water pump in that serp kit. Like off a truck or caprice. and you'll need a rad shroud. a factory f-body fan will not work.
IMO electric fans...
