real57vetteguy
11-28-2013, 01:36 PM
As some of you know by a previous thread I am making some changes to my 65 olds 442 project! The Aluminum headed 468 is getting a makeover consisting of:
CNC head and intake port job 240 cfm @ .600 Stock 321 cfm @ .600 after CNC port work
replacing 1-3/4 poor fitting hooker headers with 2" runner 3.5 collector ARH headers
Cam change from HYD to Roller 242/246 598/605
7 QT pan
better brackets for ALT and air cond
Bump the compression a little
removed 2-1/2" Magnaflow cat back system
Okay I mentioned previously that i seriously HATED the magnaflow sound on my car, maybe it was partially the X pipe but it honestly had a street bike/diesel truck/import sound to it, idle sounded nice but 2k and up it was horrible.
I am leaning towards spintech long case mufflers (the quietest ones made) I should realistically be making 520-540 hp after the changes. Its my understanding that I need to be running 3" and the car sits a bit low. I ran across Ram Air Restorations and gave them a call. He has a 3" oval kit for my car that would go to the long case spintechs but I dont like his tail pipes, I might get the kit without tailpipes and order a set of tail pipes from Flowmaster or have them done locally. My question is this.. The fellow at Ram Air restorations suggested I run a 3.5" oval x pipe to a spintech with a 3.5" oval inlet and a 3" round outlet to 3" tailpipes. I couldnt understand the reason why? The 500 HP range doesnt need 3.5" exhaust. Any ideas????? ALso I am worried about running another X pipe, if this one sounds like crap I am going to be pretty upset at spending all that money.
7 QT pan
