Results 1 to 10 of 10
09-06-2005 #1
- Join Date
- Jan 2005
- Location
- Houston, TX
- Posts
- 143
Wilwood Rear Calipers and QA1 Shocks
I trying to install a Wilwood rear disc brake kit (with emergency brake build in) on a 69 Camaro. The Camaro has a 12-bolt rear end, Global West leaf springs, and QA1 shocks. The QA1 shocks have the resevoir at the bottom (making them fat at the bottom) and mounts on the rear of the axle on the driver's.
The calipers also mount on the rear of the axle since the emergency brake cable comes out the front. The shock and caliper are hitting on the driver's side.
Anyone else have the combination?
All I can think of, is the rotor the entire assemble a 180 degrees on the driver's side. This would move the caliper to the front and the e-brake to the rear. I have the lokar cables, so I have ton of cable.
09-06-2005 #2Phillip
Originally Posted by Phillip_L
I don't know why I did not think of this before but..during the many years I used to work in Brakes, Alignment and Suspension I can remember that many of the Premium Brand Shock companies claimed that there shocks could be run both right side up and up side down. The only issue you may run into are the mounts...not sure what they are on your first gen but changing them (the mounts) may be easier than you think. I used to do it all the time. I would rather see you do this than what we discussed on the phone. Call your shock supplier and find out if you can run the shocks either way.Laramie Torres
09-06-2005 #3
- Join Date
- Jan 2005
- Location
- Houston, TX
- Posts
- 143
This will not work with QA1's (Bolt through one end and threaded on the other). It would also probably interfer with the wider tires if flipped.
09-09-2005 #4
- Join Date
- Jan 2005
- Location
- Houston, TX
- Posts
- 143
I figured out a way to make it work. I did have the move the caliper to the front, but I did not move the e-brake. It is still located correctly.
Phillip
09-10-2005 #5Sweet!! I am glad this worked out for you. I will remember this next time someone brings up the QA1 shocks.....Huh kind of strange that no one else here seems to have run into this.
Laramie Torres
09-14-2005 #6
