View Full Version : Rim-Tire widths for 69 F-body with Ride Tech Tru Turn and mini tub
jlwdvm
11-25-2013, 06:38 AM
Getting close to ordering a rear end and rims-tires for my 69 Firebird project. I am working with a stock sub frame, Wilwood 6-piston brakes, Ridetech stage 2 with coil overs, muscle bars, and Tru Turn. The rear has already been mini-tubed and the upper cradle welded in. I am wondering what rim dimensions are needed to get a 275mm to work up front and what is needed to get a 335ish in back. Since I will be ordering a S60 from Strange, I could have it narrowed a little if I want, but not looking for a super deep dish in the rear whee (should I stick with a stock width rear?). I am strongly considering Vintage Wheel Works V40's and Dunlop Direzza ZII tires. Not sure if I will use 17/18" wheels.
chichirone
11-25-2013, 06:23 PM
I have a 69 Camaro with TruTurn, musclebar and strong arm set up from Ridetech. I'm going with a 18x9.5" wide Rushforth Livewires with 5.6" BS and a 265 Dunlop Direzza Zii tire on the front. I considered 275's but Jason from Rushforth suggested the 265's for my application. Give him a call as he has a lot of experience with different set ups on f-body's for both your front and rear applications.
cwylie
11-26-2013, 09:01 AM
My wheels are on order so give me a few more weeks and I will tell you if they fit. 18x12 rears with 54.5 mounting surface to mounting surface rear axle with a 335/30/18 tire. 18x9 5.25 backspace with a 265 from tire.
glr0212
12-19-2013, 01:21 PM
how did those front wheels and tires work? Everything fit?
cwylie
12-19-2013, 02:29 PM
Still waiting on them to show up. Should be here soon.
Chev67
12-19-2013, 05:48 PM
I am running a 18 x 9.5 with 5.625 BS with a 265 up front and 18 x 12 with 5.625 BS with a 335 in the back. At the alignment shop today getting ready to hit the street. Full Ridetech setup with True Turn.
Chev67
12-19-2013, 05:50 PM
https://www.pro-touring.com/threads/93691-1969-Camaro-Build-in-PA
jlwdvm
12-24-2013, 01:25 PM
If I remember right you are running a narrowed rear end? I ordered 275 and 315 Toyos today. I had to go with 315's in the rear because the V40's I want to use are only available up to 11" wide. The 275-315 difference will probably be better for the track anyway. I also got a Percys Wheel Rite tool....we'll see if it works.
71RS/SS396
12-25-2013, 04:20 AM
I can't help with the front size but I would stick with 18's since 17's are fading away. Also are you aware that the R 888 are NOT legal for GG, ASCS, and USCA ?
jlwdvm
12-25-2013, 05:48 AM
Ya...I went with 18's. I won't be entering any sanctioned events yet, I need to work on my driving skills! Track Attack and instruction at track days is a start. Right now I track my Boss 302, but hope to have my Firebird moving by next fall.
jlwdvm
12-28-2013, 08:59 AM
I got my Toyo R888s already! I have a Percy's Wheel rite tool. Any tips on measuring for proper back spacing on the front and rear? I will be using that info to order a rear end at the proper width too.
chichirone
03-28-2014, 08:34 PM
Everything fits great. I ended up with 255's as the 265's were unavailable. I just completed the USCA event at TMS and had no issues. The Ridetech team checked out the setup and there's plenty of room for a 275 up front.
jlwdvm
03-31-2014, 06:32 AM
My V40 rims in18x9.5 with 6" back space for the front should be here this week. I hope to get the Toyo R888 275's mounted up soon. There is a lot of debate on if and how this set up works!
regal454
03-31-2014, 06:47 AM
Please post some picks and feedback once you get the wheels and tires on the car.
regal454
05-29-2014, 03:32 PM
Joe,
Did you get your wheels and tires mounted on your car? If so, how did they fit?
Formula43wheel
05-30-2014, 07:47 AM
I would suggest a 275/35-18 on a 9.5X18 wheel as it will look much better than a 265/35-18. The 265 is short at about 25.0" in diameter as the 275 is 25.7" OD. The 265 will look more like a rubber band on the wheel, which I do feel doesn't looks too appealing on a muscle car. Just my 2-cents :)
Good Luck and post some pics!
Leadfoot1
10-01-2014, 07:29 AM
Ever got those 6 inch bs wheels on joe??
Lead
jlwdvm
10-02-2014, 03:37 PM
103572103573103574103575103576103577103578Sorry... I lost track of the thread. I have a build thread going that shows a lot of pictures https://www.pro-touring.com/threads/102040-1969-Firebird-TA-clone-track-car-build
I think going with the 6" BS was a good move. All of my suspension clears the rims. I will have to alter the inner fender and fender lip a little. If I remember right, the tire barely rubs the sub at full left lock on the drivers side.
TheJDMan
10-02-2014, 05:35 PM
Remove the stock fender bolts and replace them with button head allen head bolts. It will save your tires from snagging the bolt heads.
Nativefx
10-03-2014, 07:54 AM
It looks like you will hit the fender at full turn once the suspension is compressed? Or is that just the angle of the picture??
jlwdvm
10-03-2014, 09:18 AM
Yes, some fender massaging is in the future.
130fe
10-03-2014, 10:23 AM
What is the rear wheel specs? Are you running a stock wish rear? Any info would be appreciated. Thanks!
jlwdvm
10-03-2014, 11:44 AM
The rear is a stock dimension Strange 9" with Wilwood D154 rotors and rim measurements of 18x11 with 7" back space with a 315 tire.
