View Full Version : Who makes a good A-Body spindle?
SleeperLark
11-23-2013, 09:22 AM
I'm just getting back into modifying the suspension on my GM A-Body. Back in the day there was no name for what we were doing and you had to use the spindles off of a B-Body or a 73-77 A body to get camber gain. So far, I see that Detroit Speed & RideTech offer tall / drop spindles. I don't know if the DSE spindles are compatible w/ stock A-arms or even available separately. My car is completely original (currently) and I'm looking to upgrade it to disc brakes and correct the suspension geometry without going overboard.
I know I will need;
Spindles
Springs
Shocks
Swaybars
Bushings
and possibly Rear Link Arms
I'm not looking for the cheap way out, just don't want to spend more that necessary. Like do I need tubular lower A-arms? The complete kits offered by some of the Mfg offer optimum performance / guaranteed compatibility, but the cost is pretty steep.
andrewb70
11-23-2013, 09:28 AM
http://www.speedtechperformance.com/index.cfm/page/ptype=results/category_id=76/home_id=-1/mode=cat/cat76.htm
ChevelleNV
11-23-2013, 09:33 AM
don't waste you time trying to piece something together to try and save a few dollars, your just asking for a headache. just bite the bullet and buy a complete setup from one of the bigger companies making the parts like Ridetech, SpeedTech, or DSE and it will all bolt together and just work like its supposed to, and you will be so happy you did. I bought the ride tech stuff for my Chevelle and everything just worked together and is all built really nice.
There are a couple vendors on here that sell these parts and can get you a really good deal on the parts, I recommend talking to the guys over at Matt's Classic Bowties (MCB Matt). They are always running forum members specials and are easy to deal with. I have bought several items from them at some pretty steep discounts.
SleeperLark
11-23-2013, 10:07 AM
Thanks ChevelleNV, I was checking out the RideTech kits. I'm all for buying a kit or at least compatible parts from one manufacturer. I'll take a look at your build thread.
ChevelleNV
11-23-2013, 10:55 AM
My build thread is really outdated... has posted on it in almost a year....
Nothingface5384
11-23-2013, 02:43 PM
i dunno about buyig a kit as theirs always something you may not like about it..such as spindle design, or the bundles swaybars or w/e
The 2 best spindles to consider is the ATS afx spindles by Speedtech and the spindles from L&H kustoms
If you def plan to go 17+ go speedtech
if you want to stick with 14s/15 or switch like to swithcbetween 14/15 to 17+ then L&H
if you plan to go airride then obviously go with their spindles as its made to work the best together
you can always just rock stock spindles and go taller upper/lower BJ
The kit i pieced together was
Stock disc spindles w/ stock steering arms
taller upper/lower BJ through SC&C
spc upper/lower arms
DSE front splined sway bar
Hotchkis steering components
Full Rear DSE kit
spc drop springs with hp1000 shocks all around
SleeperLark
11-23-2013, 09:46 PM
Thanks for the leads. I do like the ATS/Speedtech spindles, but I'm not going after market brakes on this car. I'm just starting to develop this in my head and I haven't seen all the products out there yet. So far I like the RideTech Spindle w/ stock lower A-arm and maybe a after market upper. The DSE rear links are top of my list. I need to catch up on the new technology and products. I crewed on circle track cars for years and most were 68-72 base cars. There are all kinds of products from Coleman, Howe, and other stock car/circle track outfits, but some of the stuff like adjustable pin mono balls are not suitable for the street.
Chevelle598bb
11-24-2013, 07:20 AM
If your not trying to get 2 inches of drop from the spindle then just use your stock spindles with tall ball joints. The tall spindles like ridetechs need to be used with their upper arms to see any gain from them. The tall ball joint swap is easy, cheap and works well.
69cutlassrkt
11-26-2013, 11:01 AM
With the tall ball joints you need a arms designed for it like spc arms. A lot of people are doing it with stock a arms but its not the right way. BTW I have talked to Mark about this cause I was going to do the tall ball joints.
bootlegr
09-15-2014, 05:01 PM
comparison 2 inch drop and stock..i am going with stock to allow the use of Howe Bump steer kit.
Call Marcus at SC&C discuss your goals for the car. He will point you in the right direction whether it is his stuff or somebody else.
don't use a bump steer kit on your Chevelle it moves the tie rod in the wrong direction....leave it stock you can improve the bump steer and camber curve with a tall lower ball joints it also helps a few other things
09-16-2014, 09:55 PM
yep, you can use it just with no spacers and crank up the caster.
killer69
09-17-2014, 08:30 AM
OR use the AFX spindle and steering arm.
Later-A-body
09-19-2014, 05:39 AM
Call Global West Suspension. They have been doing this a very long time and have complete kits or individual suspension components that also work with B-body spindles.
How about cpp??? They have good quality stuff and it won't cost u a arm and a leg , good luck
Nothingface5384
09-20-2014, 08:50 PM
how come everyone was quiet about L & H Kustoms closing doors?
they had a nice alternate to the ATS AFX spindle
pretty sure cpp is chinese..may as well rock stock spindles at that point and do tall BJs
only 2 aftermarket spindles worth swapping to over stock is Ridetech and Speedtechs ATS AFX spindles
andrewb70
09-21-2014, 02:33 AM
I never cared for the L&H spindle.
The CPP spindle is a cast iron ripoff of the Speedtech ATS AFX spindle. I would never use it.
Nothingface5384
09-21-2014, 08:47 AM
I liked it for the fact that it gave you an option to retain 14/15in wheels , for people who wanted a stealthjy pro-tour setup
Hellwigs upcomming FSB will make chooseing the AFX spindle even more easier..hoping it'll let us run a 295 on a 10in wide rim, thatd be the tits there
