rat_rod_russell
11-15-2013, 05:08 PM
https://static1.pt-content.com/images/pt/2013/11/1957ChevySedanM-1.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/1957-Chevy-Sedan.jpg)
I figured I finally needed to get the Nerd Rods TriFive car posted up. We plan on doing lots of touring and autocross in this little guy and giving lots of rides. Big power on the cheap and lots of tire on the ground. With luck we'll also get to use this car to make some instructional videos for guys looking at their own DIY frame.
Build List
Nerd Rods TFC4-S3, TriFive C4 Stage 3 Rolling Chassis
TFC4-BLK, Nerd Rods Brake Line Kit
TFC4-HK, Nerd Rods Handling Kit
Includes Rod End Rear 4 Bar
Rear Sway Bars Ends
Allows for larger tires on the ground and better handling
TFC4-LSFS-TT, Nerd Rods LS Fuel System
20+ Gallon Aluminum Tank and mounting hardware
Tank modified for STS Twin Turbo configuration
Stainless Steel Hard Lines
AN Braided Steel Flex Lines
AN Fittings
Aeromotive Stealth Fuel Pump, 340 LPH
Aeromotive Fuel Pressure regulator with boost reference
LS based LQ4 6.0L Engine
STS Turbo Cam
4130 Push Rods
Partiot Valve Springs
T56, Camaro Configuration
Stage 3 Spec Clutch
Steel 3-4 Shift Fork
Brass Shift Pads
Built By Koeting Wagon Works in Austin TX
Short Throw Shifter
C4 Corvette Suspension, 1990 HD
Dana 44, 4.10 Gears
12" Rotors, Drilled and Slotted
Twin Piston Corvette Front Brakes
Single Piston Corvette Rear Brakes
2.75 ratio Corvette Rack
Corvette C4 ZR1 Sway Bars
Powder Coated Suspension, Brakes and Sway Bars
QA1 Double Adjustable Shocks and springs (Everyone gets double adjustable shocks when they buy from us. I'll go more into why later)
So this is how she showed up after we traded for her.
https://static1.pt-content.com/images/pt/2013/11/S01-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-01.jpg) https://static1.pt-content.com/images/pt/2013/11/S02-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-02.jpg) https://static1.pt-content.com/images/pt/2013/11/S03-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-03.jpg)
https://static1.pt-content.com/images/pt/2013/11/S04-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-04.jpg) https://static1.pt-content.com/images/pt/2013/11/S05-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-05.jpg) https://static1.pt-content.com/images/pt/2013/11/S06-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-06.jpg)
https://static1.pt-content.com/images/pt/2013/11/S07-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-07.jpg) https://static1.pt-content.com/images/pt/2013/11/S08-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-08.jpg) https://static1.pt-content.com/images/pt/2013/11/S09-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-09.jpg)
https://static1.pt-content.com/images/pt/2013/11/S10-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-10.jpg) https://static1.pt-content.com/images/pt/2013/11/S11-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-11.jpg) https://static1.pt-content.com/images/pt/2013/11/S12-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-12.jpg)
https://static1.pt-content.com/images/pt/2013/11/S13-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-13.jpg) https://static1.pt-content.com/images/pt/2013/11/S14-2.jpg (http://nerdrods.com/Images/Projects/more_door_toublemaker/00-rendering/L-14.jpg)
Build List
Rear Sway Bars Ends
AN Fittings
STS Turbo Cam
4130 Push Rods
Stage 3 Spec Clutch
Brass Shift Pads
Short Throw Shifter
Dana 44, 4.10 Gears
