View Full Version : telling a 5.3 from a 4.8 vortec?
71maroesteban
11-13-2013, 06:55 PM
So I'm looking to buy what the guy claims to be a 5.3 from a 2002 tahoo the car was wrecked the the motor is out now I know the 4.8 was also used in some cars and the blocks are the same so how can I make sure it's a true 5.3? Also and tips from veteran used motor buyers to make sure the motor isn't trash I'm driving an hour to look at it so I don't want to go buy trash thanks!
srh3trinity
11-13-2013, 07:03 PM
My 6.2l has it stamped on the back of the block. I may be wrong, but did tahoes even come with the 4.8l?
71maroesteban
11-13-2013, 07:11 PM
On the back of the block 4.8/5.3 or stamped so the stamping is the same for both :/ and yes I believe so
Mr.VENGEANCE
11-13-2013, 08:50 PM
take off a head and see the tops of the pistons..
if I remember correctly the 5.3 has dished piston tops and the 4.8s have flat tops..
TheJakeLSX
11-14-2013, 06:13 AM
This is the only way to tell the difference in the 2. Otherwise you have to pull the oil pan off and find the crank shaft casting number.
GBNL
11-14-2013, 03:55 PM
Pull a plug and shine a light thru the hole to see the piston , look for a dish piston. For a 5.3
