View Full Version : Similar dumb question
I am looking at ways to reduce my intake temps. I have a 2" cowl hood that has about 1/8" or less clearance from the top of the air cleaner to the hood, so injection systems are out. I am running a Weiand 144 supercharger and I know my intake temps have to be pretty high. My coolant flows through the intake last.
Can I reverse the flow say with a electric water pump? Its a chevy 350.
Will it help?
I have a 170*stat and she usually runs between there and 180*
paul67
09-05-2005, 01:41 AM
Is this for when you are on the street or do you drag race it and thats what you want it for.
paul67
Mostly street, occasional strip. I have spent alot of time and money to get as much HP out of her as I can. The roots style blowers put out a TON of heat and I was just looking at ways to reduce my intake temps.
I live in Florida so our daytime heat is pretty bad but even in the late evenings after driving on an 80 degree day you can touch the blower snout and its too hot to hold your hand there for more than a few moments.
paul67
09-07-2005, 04:06 AM
Some how I would think you need to give the intake its own pump and rad, will look into this i like a callenge.
paul67
paul67
09-09-2005, 07:32 AM
Ive been told there is a reverse flow pump for the sbc they altered the blades somehow.
paul67
Awesome Paul!
Thank you for spending the time to look into this. I appreciate that.
I was thinking of just putting on an electric pump and crossing the wires.
Yes no?
paul67
09-10-2005, 01:51 AM
No as the blades would be facing the wrong way.
paul67
paul67
09-10-2005, 01:56 AM
Just been on a performance web site and Edelbrock do a reverse rotation pump for small block and big block chevy try the Edelbrock site .
paul67
Fuelie Fan
09-10-2005, 03:09 AM
I think you're mistaken. Reverse rotation pumps, as I understand, are driven backwards because they're serpentine-driven and the belt is going the wrong direction, but they still pull from the rad and push into the block
paul67
09-10-2005, 03:24 AM
Saw that, but on the write up of pump 8815 short style 84-91 vette theres no mention of serpentine belts like the other 2,
see what you think.
paul67
paul67
09-10-2005, 03:47 AM
Check this file out this should answer your questions Cham, this for a turbo engine with a cooling prob thats been cured,
paul67
paul67
09-10-2005, 03:51 AM
trying again
paul67
09-10-2005, 04:04 AM
3rd time lucky
383blown
09-10-2005, 11:12 AM
You wont cure the problem by changing the direction of flow. Your trying to put out a forest fire with a garden hose. You need a superchiller* and face the fact that the hood won't work with that combo, get a larger scoop or cut the hole! or live with the high intake temps. NOS does cool things a bit but only when it's flowing.
