View Full Version : San Diego Region SCCA Street Modified (Vintage) Rules
DTM Racing
11-04-2013, 06:51 AM
Alright. After yesterdays discussion I think we have the framework for SM(V) worked out. Here are the tentative rules; if there is something wrong, let me know and l will make changes to the thread's main post.
16(a). STREET MODIFIED (VINTAGE) CATEGORY
16(a).0.A. Purpose
To serve as a membership recruitment and retention tool by providing
a natural competition outlet for auto enthusiasts using classic American
streetable
sport sedans, trucks and "hot rods" equipped with drivetrain and suspension modifications
that are beyond those allowed in the Street Prepared category.
16(a).0.B. Classes
1. Street Modified (SM), a class for sedans/coupes as described below.
16(a).0.C. Vehicle Eligibility
1. Street Modified Vintage (SM(V)):
All sedans/coupes/trucks of American manufacture built up to and including 1978
(models which were originally equipped with a
minimum of four seats and four factory seat belts, not sports car
based). Trucks and hot rods excluded, but shall adhere to the rules that follow.
a. Sample Vehicles:
Chrysler: Dart, Charger, Cuda
Ford: Mustang, Galaxie, Tourino
General Motors: Camaro, Chevelle, Impala
b. All SM eligible sedans/coupes excluded from SM for failure to
meet weight requirements(TBD) shall be moved to CP or XP as rules allow.
16.1 ALLOWED MODIFICATIONS
A. All Stock, Street Touring®, and Street Prepared category modifications
are authorized. Except as noted by these rules and the referenced
rules, vehicles must be as originally delivered including all
road-going components such as lights, wipers, interior from rear of front seats forward, heater, etc.
B. Competitors may pick and choose between all Stock, Street Touring
®, Street Prepared, and Street Modified category allowances
when preparing a Street Modified category car. Apparent conflicts
between inherited rule sets from Section 16.1.A shall not prohibit
any specific inherited allowance. Allowances inherited from Section
16(a).1.A may not incorporate Street Modified-specific allowances. Aftermarket
spec parts may not be used to substitute for parts which are
required to remain stock.
C. Brakes, including calipers, caliper mounts, disks, drums, lines, backing
plates, pedals, boosters, master cylinders, handles, ABS systems,
proportioning valves, etc., are unrestricted. Brake rotor/drum
friction surfaces must be 100% ferrous metallic. Carbon or ceramic
composite brake components (except pads) are expressly prohibited.
Standard parts, per Section 12.4, are exempt from this restriction.
A functional, redundant emergency (parking) brake is optional.
D. Drivetrain and related components (induction, ignition, fuel systems,
etc.) are unrestricted except for the following limitations:
1. Engine block must be a production or aftermarket unit manufactured,
cast of the same alloy and badged
the same as the original standard or optional engine for that model.
Badges that exist as marketing aliases for the manufacturer
will be recognized as equivalents. Swaps involving makes related
only at a corporate level are not recognized as equivalents. Models
produced as a joint venture between manufacturers may utilize
any engine from any partner in the joint venture, provided that
an engine from the desired manufacturer was a factory option in
that particular model (e.g., Eagle Talon, available originally with
either a Mitsubishi or Chrysler engine, may use any motor from
Chrysler or Mitsubishi). This allows engine blocks manufactured
as production units for sale in other countries such as Japan or
Germany.
2. Maximum engine displacements per class are specified in
Appendix A(TBD).
3. Fuel System
a. Any fuel line(s) may be used. All non-standard fuel line(s) passing
through the passenger compartment shall be made of metal,
metal braided hose, or equivalent (e.g., Nomex, Kevlar, or
nylon braided hose) with AN Series threaded couplings, or entirely
covered and protected with a metal cover.
b. Any fuel pump(s), filter(s), and pressure regulator(s) may be
used. Such components may not be located in the passenger
compartment but their location within the bodywork of the car
is otherwise unrestricted. If a mechanical pump is replaced,
a blanking plate may be used to cover the original mounting
point.
c. A cool-can, not exceeding one gallon in volume, may be used.
The cool-can may not be installed in the passenger compartment.
d. The fuel tank may be modified or replaced. If the fuel tank is
modified or replaced, the following restrictions apply:
1. No part of the fuel tank or fuel cell shall be closer than 6”
(152.4mm) to the ground unless enclosed within the bodywork
and mounted above the floor pan. A metal bulkhead is
required that provides total separation between the driver
compartment and the compartment containing the fuel tank
and/or filler/neck. This includes fuel tanks that are flush
mounted with driver compartment panels or otherwise exposed
to the driver compartment. Fuel filler doors in the driver
compartment must be positively fastened (non-metallic
fasteners are not allowed).
For the purposes of these rules, a fuel tank consisting of a
structure containing a fuel bladder is considered to be the
entire fuel cell including the containing structure. The containing
structure of a fuel cell does not qualify as a bulkhead.
A separate metal bulkhead must isolate the fuel cell from the
2. Internal body panels may be modified to accommodate the
installation of the fuel tank as long as such modifications
serve no other purpose. In the event installation includes encroachment
into the driver’s compartment, a metal bulkhead
shall prevent exposure of the driver to the fuel tank.
3. Fuel tank breathers shall not vent into the driver/passenger
compartment.
4. Minimum capacity of a non-standard fuel tank/cell shall be
no less than 5 gallons.
Engine and drivetrain mounts are considered part of these
allowances and any material is permitted. The allowances of
Section 16(a).1.P may be used to affix brackets, but these brackets
shall serve no purpose other than engine and drivetrain
mounting (e.g., they may not provide chassis stiffening).
E. Suspension components are unrestricted as long as they use the
original attachment points. Modification of factory pickup points shall be
allowed by elongation or drilling of new holes (e.g. Shelby "drop mod")
For the purposes of this rule, “suspension”
is defined as any item that is designed to move when a wheel
is deflected vertically. This includes shocks/struts, control arms,
steering knuckles, uprights, etc., but not tie rods, steering racks, and
subframes. In addition, shock absorber/strut upper mounts are to be
considered suspension components.
F. Steering modifications are permitted as follows:
1. Steering components, including the steering rack and/or box, tie
rods, idler arms, power assist devices, and related components
may be replaced, added, moved, or removed. Wheel-mounted electrical
switches such as those for the horn, radio, cruise control, or shifter
may be relocated and/or replaced, or eliminated.
2. Rear-steer devices may be replaced with solid links.
3. Supplemental steering gear boxes or steering quickeners are allowed
as long as they are mounted in accordance with Section
16.1.F.1.
4. Steering wheels and associated mounting hardware may be replaced.
This does not permit removal or modification of the steering
column or column-mounted accessories. OE wheel-mounted
electrical switches such as those for the horn, radio, cruise control,
or shifter may be relocated and/or replaced, or eliminated.
G. Subframe connectors are allowed as per Street Prepared Section
15.2.E.
H. Subframe bushings may be replaced with bushings of any material
as long as they fit the original location. Offset bushings may not be
used.
I. Front hoods (engine covers), engine covers, trunk lids and hatches
not containing glass, front fenders, rear fenders not part of chassis
structure (unibody), front & rear facias, and side skirts may be
modified or replaced, and may be attached with removable fasteners.
Associated hardware including latches, hinges, window washer
system, and hood liners may be modified, removed, or replaced.
Main body and frame or unitized structure must be of 1978 or earlier
construction. No aftermarket replacements of body or subframes shall
be allowed. Vehicle VIN must correlate with vehicle make and model.
J. Tires shall be limited to 200 tread wear rating by the manufacturer.
K. Rear passenger seat(s), including restraints and associated hardware
may be removed.
L. Aerodynamic Aids: Wings may be added, removed, or modified. Non-
OE wings may only be attached to the rear deck/hatch area behind
the centerline of the rear axle. The total combined surface area of all
wings shall not exceed 8 square feet as calculated per Section 12.9.
The number of wing elements is limited to 2.
Wings, and any component thereof, may not extend beyond the vehicle
width, as defined by the outermost portion of the vehicle doors,
less mirrors, door handles, rub strips, and trim. In addition, no portion
of the wing or its components may be more than 6” forward of the
rear axle, more than 0” beyond the rear most portion of the bodywork,
or more than 6” above the roofline of the vehicle, regardless of
body style. For convertibles and roadsters, the highest portion of the
windshield frame will be considered the highest portion of the roof.
Reinforcements to the wing mounting area may be used, but may
serve no other purpose. Body panels to which a wing mounts must
remain functional (e.g., trunk lids and rear hatches must open). Wing
endplate surface area is limited to 200 square inches each and limited
to a maximum of 2.
Except for standard parts, wings designed to be adjustable while the
car is in motion must be locked in a single position.
Canards are allowed and may extend a maximum of 6” (152.4mm)
forward of front bodywork/fascia as viewed from above. No portion
of the canard may extend past the widest part of the front bodywork/
fascia as viewed from above. Canard area will be measured in the
same manner as wings using Section 12.10. Canard area may not
exceed 15% of total wing allowance. The sum of canard area and
rear wing area may not exceed the total wing allowance.
M. Front splitters are allowed and shall be installed parallel to the ground
(within ±3° fore to aft) and may extend a maximum of 6” (152.4mm)
from the front bodywork/fascia as viewed from above. Splitters may
not extend rearward past the centerline of the front wheels. No portion
of the splitter may extend beyond the widest part of the front
bumper/fascia as viewed from above.
N. Removable OE hardtops, T-tops, targa tops, sunroofs, moonroofs,
and similar roof-mounted panels may be removed/replaced with alternate
panels provided that the area of interface is limited to the
original perimeter of the t-top, sunroof, etc. or utilizes the OE panel
mount points, and that the contour of any replacement panel surface
does not vary from the contour of the part being replaced by more
than 1” (25.4mm) in any direction. The material used to construct the
alternate panel and the method used to attach it to the interface is
unrestricted. Any actuation mechanism and the associated wiring, if
any, may be removed. Vehicles utilizing alternate (non-OE) hardtops
will be considered as open cars in regard to Section 3.3.1.
O. Radio/Stereo and airbag equipment and/or its component parts, in
cluding wiring, control modules, antennas, amplifiers, speakers and
their enclosures, etc. may be removed provided the part added, removed,
or replaced serves no other purpose. Any visible holes that
result from the removal of equipment must be covered with a cover
of unrestricted material. Covers may be used to mount gauges,
switches, etc.
P. Any minor modification, intended to allow or facilitate any allowed
modification, is permitted as long as it does not provide any intrinsic
performance benefit in and of itself, does not provide a weight reduction
of more than 1 lb, and is not explicitly prohibited elsewhere
within these rules.
This rule is intended to allow minor notching, bending, clearancing,
grinding; the drilling of holes; affixing, relocating, or strengthening of
brackets; removal of small parts, and similar operations performed
in order to facilitate the installation of allowed parts or modifications.
Minor strengthening, without relocation, of original chassis/suspension
pickup points is allowed. Examples include welding washers
restricting control arm mounting bolt movement, local reinforcement
of control arm chassis mounts, etc.
Competitors are strongly cautioned to make the minimum amount of
modification required to affix a given part, and to not make unduly
tortured interpretations of this rule. Modifications to the firewall in
order to allow for increased engine setback, and any modification
that changes the location of a suspension pickup point, are explicitly
forbidden. Plastic under-trays and covers below the vehicle may be
removed or modified as necessary to facilitate other compliant modifications,
but not added or enlarged.
Q. Ballast may be added. Ballast must be a maximum of 50 lbs. per
segment. It must be securely mounted within the bodywork.
R. OE side mirrors may be replaced by aftermarket units, provided they
mount in the same location, perform the same function as the OE
mirrors, and have a reflective surface area greater than 15 sq. in.
S. OE “pop-up” headlights may be replaced with static headlights, provided
the replacement units are intended for automobile use on public
roads as a primary means of illumination, and retain high and low
beams as originally provided by the manufacturer. Minor repositioning
of the headlights is allowed to accommodate the alternate headlight,
but the unit may not be relocated and the repositioning may
servce no other purpose. All associated hardware may be removed,
replaced or modified.
T. Alternate subframes are allowed to facilitate engine mounting only.
Suspension pick-up points on the subframe must retain standard geometry.
Weight of the subframe must be equal or greater than the
standard unit.
16.2 MINIMUM WEIGHTS (TBD)
Classes, displacements, and minimum weights are listed in Appendix
A. For the purpose of determining minimum weights, a mid-engine vehicle
is defined as one having a chassis configuration where the engine
block is not located entirely in front of the driver’s seat and is not far
enough back to be considered a rear-engine vehicle. Adjustments to
minimum weights are shown in Appendix A.
soloracerSD
11-04-2013, 05:11 PM
Plenty of info in that draft of build rules.Before I get into reading it.I want to let anyone out there.
WE have a 2 day event the weekend before Good Guys Del Mar Nov 22-24.Ours is 16,17..the 16th being a practice.So get the car dialed in so that you can impress at the Good Guys event. Our SCCA event will be hosted by the SDAD club.They do a great job of laying out fun courses.It will be on the WEST PARKING lot of Qualcomm stadium..Course should be more then a half mile in length.
info can be found at sdr-scca.com But you can get info here just by asking.Saturday is preregister practice.Sunday Championship or X run practice.You don't need to know what class your car fits in to run you don't even need a class.Street Unlimited class covers every thing If you want a competitive class we can suggest one to.
72BBSwinger
11-04-2013, 08:08 PM
Factory attachment points for suspension, so does that mean stuff like DSE sub-frames and Quadralink are not allowed? Not picking on DSE, just was first example I came up with. If a car has aftermarket subframe it hardly can have "factory attachment points". Edit: I see aftermarket sub frames are dis-allowed.
soloracerSD
11-04-2013, 09:45 PM
I can only speak for whats in the rules now.SCCA Street Modified.No subframe changes or bolt in IRS subframes are allowed.But some agree if you use the front untouched leafspring mount to attach a lower control arm.Then add a upper control arm and pan hard bar/watts link.You can slip a leafspring to fourlink convertion in SM..But the question is how do you mount the coil spring.You would have to use a coilover and use the shock mount at frame that is stock.Minimum amount of strengthening is allowed in SM.In CP you can change a leaf to fourlink with out much restriction.CP are tubeframe cars SM are not.Best answer for that would be Doug Gill at SCCA main office SOLO department.
THe Draft of a San Diego SCCA Street Modified Vintage cars .Was written by Dan W. For a correct answer on that he is the one to answer.Most of it is right off the SCCA rule book for Street Modified.Find online solo book at SCCA.com read pages 81 to 113 most of what you read above is in last 10 pages.
DTM Racing
11-05-2013, 06:36 AM
As a reminder, this whole thing is currently in pencil. We are planning a dinner meeting at Del Mar Goodguys to discuss and debate further.
-The spirit of the rules are for "bolt-on" cars to compete. The 200tw keeps it affordable for folks to compete. I personally feel that if you can afford a full custom subframe and link rear systems, you can afford slicks and should be fighting in CP or XP.
-The two posts above make me think perhaps we should allow the addition of two suspension pick-up points (one at the axle and one at the chassis) for the addition of a watts link or panhard par?
Tomswheels
11-05-2013, 09:03 AM
I know its not what some want, but I like a little bit more run what you brung rules mentality. If someone has a full aftermarket coil over set up, and an aluminum LS motor, I want to run against them and try and beat them, even on my stock style suspension and old school iron block...
DTM Racing
11-05-2013, 09:33 AM
Can we at least build the car before you start hurling idle threats, lol?
Tomswheels
11-05-2013, 10:49 AM
Id like to quote Cole Trickle from Days of Thunder here: "Theres nothing I cant do with a race car"....
QuarterD25
11-05-2013, 12:12 PM
Harry Hogge: No, no, he didn't slam you, he didn't bump you, he didn't nudge you... he *rubbed* you. And rubbin, son, is racin'
struck by Lightning
11-05-2013, 02:23 PM
"I knew the car would hold and we could pass to the outside once Harry told me about the special sticker tires he put on at the last stop"
Good to see trucks included in SM(V).
Tomswheels
11-05-2013, 02:54 PM
Switching movies,
"I'm just a big, hairy, American winning machine"
soloracerSD
11-05-2013, 04:26 PM
SCCA SM already allows adding Pan Hard Bars and watts links.It's part of the rear live axle rules in Street Prepared(ESP).I believe the adding of 2 traction bars are legal to.Street Prepared if leafspring must stay so.SM doesn't have that restriction.Live axle can be of any make and no attachment restrictions at axle.So if you fit a control arm in the stock front leafspring socket.WEll I've gone over this stuff before so I'll stop here...:)
soloracerSD
11-05-2013, 05:06 PM
84647Heres a shot of 2 of our popular classes that the PT guys run in.One of our lowest turn out of PTs this year ONE!.But check out what Dan did in a Honda.Who would of guessed he would be fast in a Honda too.... Total entries was in the 160s not 61 that was that page
I'm all about seeing good competition.Also would like to see all the trick Pro-Touring cars show up.One of the ideas I suggested was also SM based class. SM is all original looking lights LEDs are fine,4 seater with dash, door panels two front seats some carpet.Radio and heater not a issue, but are required in SM.If it's stripped out It's CP car to me.So spend a day putting it back in.Pro-Touring is to be street comfortable right.I'm for open frame rules and frame support.BUT roof and floor pan must remain intacked.We have had 4 altered subframed and attachment point changed cars already 2 Camaros,truck and 63 Falcon with home built 4 link.We will still have the SM class we have now.Out of the 8 that ran in that class last event a 200 tw car was 2nd .Look for the FRS.Mark in his 66 Chevelle was less then a second of mid pack on 200tw.Another SM rule would be.You must use stock bumpers.So stocks go back on or that rule isn't followed.CP again doesn't have that restriction.
Maybe allow any make 1978 and older and use the SM sports car base exclusion bumped to SSM rule.Thats Porsches and Datsun Z 2+2s and others.One member told me all makes would have to be allowed.No one else has mentioned that.It might be just one guy's idea.I'm a MAZDA guy and it doesn't bother me.:)
Dan one thing I read in your Draft wasn't clear.Or maybe it was my aging eye sight.In section I,, I remember the rule being something like this. Body Panels....Hood,front Fenders and trunk can be made of different material and modified.Panels attached to glass must remain stock.Example Vegas fast back and Mustang 2 fastback rear hatches.... Correction it was my eyes your draft does follow what's in the SM rules.
Bryce
11-08-2013, 05:11 PM
I guess I like it, but my car does not fit the rules. But I am okay just competing.
soloracerSD
11-24-2013, 11:35 AM
85828From what I've heard in last discussion at GG Del Mar.All Vintage Muscle cars will get to run together in a proposed local class.Then I heard of some kind of 10th of a second time some cars would have added to their laptime.At first was puzzled and I don't know the details of the Idea.
Then I realized we already do something like that at SCCA events.We call it PAX Indexing. A slower classed Car's laptime is multiplied to a PAX index # that can equalize it's laptime to a faster classed car's laptime PAX INDEX.I've gone over this before a year ago on thread "San Diego Autocross"I used P1=XP,FP,CP as a example. It was text 85#
The attached really goes over it well.AM class cars are the Fastest SCCA Autocross cars .If you built your own F1 car that would be it's class.JC is the slowest It's a childrens GO-KART and we have everything in between at our events
This is just food for thought.
If you check our race results.You will see group classes ..RTR,P1,P2 and the class just called PAX which is really Champions PAX. These grouping of classes get their winner by PAX INDEX
soloracerSD
11-24-2013, 12:26 PM
To add what I posted above.
In a class where the cars are somewhat alike.But allow any size motor mod.There are other ways.The SCCA SM class details at beginning of thread it reads"2. Maximum engine displacement per class are specified in Appendix A and 16.2 Minimum weights PG 199-200
200xliters+1800=weight of car.. A 5 liter car is 2800lb. Any car at 3100 doesn't have to add any weight.Weight control ends at 3100.So any size motor can go in a 3100lb car.(If a car is force induction add 1.4 to liters)
A few body panels and removing rear seat are really the only way allowed to drop weight in SM.Read upper details
There are weight drop allowances though.
If on 275 wide or narrower tire you can drop 200LB
If live axle -25lb per liter that helps against IRS cars
Now this allows for some light cars. Hard for even a Mustang to get to SM minimum weight rules and no fun for Chevelles,Chargers,Roadrunners,Fairlanes. good for a 5liter Vega.You can be over weight just not under weight
Just change 200xliters to 260xliters
A 5 liter is 3100 on 275 tire it's 2900lb put end of control weight at 3500lb
Maybe a aftermarket subframe car 300xliters.SM all wheel drive subarus,wrx,EVOs are 300xliters
It probably fits where your at now. and it's simple 3 grade math.I'm curious to see how your cars fit this
JUST MORE FOOD FOR THOUGHT TO SEE HOW IT"S BE DONE BEFORE.
I probably wouldn't impose any of these rules in my last 2 texts the first year.The weight is a good base for a Gentlemen rule.SDR SCCA doesn't provide scales.Robbie Robinson did offer to bring his for one event.I asked him about this a year ago.
I don't have a Pro-touring car but have been racing SCCA solo2 autocross for 20 plus years.Just sharing what I know..OH! CP class 5 liter is 2700 and anything bigger then a 5 liter starts at 3000lb C-Prepare.
soloracerSD
11-26-2013, 12:51 PM
86140I could be beating a dead horse here.But here I go..If there ever was a National SCCA Pro Touring class.A equalizing formula would come into play.They wouldn't let a big HP motor and tire car run all over a small displacement small tire car.It would be done a lot like SM ,XP or CP classes..most likely SM weight to displacement liter rules.It would be the same in other series.Class SMF is new and that's how it's being done.THis is my experienced guess.PIC is from National Tour SD I think 2900lb for 63 Falcon
Here's examples of what I have above.
a 289 is 4.7 liters a 400ci 6.5
take the 200xliter changed to 260xliters
260x4.7+1800=3022 most likely on a 275 tire or smaller drop 200lb= 2822 a Falcon and Mustang II come to mind even a Fairlane.There is also the live axle allowance weight drop
260x6.5+1800=3490lb if on a 275 not bigger 3290lb a Chevelle comes to mind
lets say a aftermarket subframe had people thinking that's half a modern car.Okay SCCA SM
is 200xliters for rear wheel drive/ All Wheel drive is 300xliters
for SM-V PT 260xliters / aftermarket frame 300xliters so a little penalty
300x6.5+1800=3750 most likely on tires wider then a 275 so 3750 but with a max control weight of 3600lb that would be it's minimum weight.a 69 Camaro comes to mind
If it was a after market subframed car with a 5 liter
300x5+1800=3300lb stock frame would be 3100
You guys all look legal to me.
Bryce might need to run with a full tank to make weight,or use 25lb to liter drop for live axle
Alcino is good
Rich good
tyler good
ETC.
even Matt A good.
LET's RACE!
Some of you have run a tire smaller then a 275.getting to a 275 and keeping 200lb weight drop helps a lot.
I know you guys can built awesome cars,So the math should come easy.SM-V might seem over detailed at first.But classes allowing MANY MODs are done this way to promote closer competition. Just weigh the top 4 finishers 5 times a year..4 might be all that care about winning and points. Or it could just be a exhibition class of fast cars.Kind of what it is now That's fine to.
YES I"M into details.But I don't understand them till I read them twice.I think that's normal for many of us.
iRoush
12-26-2013, 06:40 PM
looks like you guys are getting your wish according to the 2014 solo rulebook draft!
CAM - APPENDIX B
APPENDIX B - CLASSIC AMERICAN MUSCLE (CAM)
Rationale: The purpose of CAM is to attract automobile enthusiasts to
SCCA who are currently interested in and/or participating in the Goodguys
® Autocross events or other similar events for “classic” vehicles
(e.g., Street Machine, Muscle Car, Hot Rod, Truck, Street Car, Late
Model, etc.) built in North America by manufacturers based in the US
(e.g., “The Big Three” – GM, Ford, and Chrysler). These avid enthusiasts
would largely be a new and different group of folks to join with us
as SCCA® members and participants.
However, many of these types of cars may not have a favorable classifi
cation at their local SCCA® Solo® events. By having a simple, single
set of rules used across the country, these new autocross enthusiasts
would be able to participate in multiple Regional Solo® events
with a more consistent experience. Additionally, this gives SCCA and
the Solo® Events Board an opportunity to see the viability of this type
of participation at all levels of Solo® events. Therefore, Regions are
encouraged to offer this program and to encourage Classic American
Muscle car enthusiasts to join the fun at your SCCA Solo events!
Eligible Vehicles
• Vehicle must be considered a “street legal” (lights, wipers, etc.),
US-domestic automobile of front-engine/RWD configuration or a
“pick-up” truck. Must be licensed and insured.
• Vehicle must pass the mandatory safety inspection (tech) and be
in compliance with Section 3, Vehicles, of the 2014 SCCA® National
Solo® Rules.
• Vehicles must weigh 3000 pounds or more.
Body
• All body panels must be present in the original standard locations
and may be modified or replaced. EXCEPTION: High-Boys
(1954 and earlier), Roadsters (1954 and earlier), and Trucks
(1940 and earlier) are not required to have fenders or hood sides.
• All glass must be present. Side glass components may be replaced
by Lexan®.
• Interior must be finished and have minimum seating for two adults.
• The fuel tank/cell must be separated from the driver/passenger
compartment by a metal panel/bulkhead. The fuel tank/cell shall
not vent into the driver/passenger compartment.
Wheels and Tires
• Any metallic wheels are allowed. Non-metallic wheels must be
certifi ed from an appropriate, recognized standards organization
(e.g., FIA, SFI, SAE, TUV, etc.).
• Only DOT-approved tires with a UTQG Treadwear Grade of 200
or more are permitted.
Body Electrical System
• Electrical components and wiring are unrestricted.
Brake System
• Brake system and components are unrestricted.
Suspension and Steering
• Suspension and steering components are unrestricted. Method of
attachment is unrestricted.
Engine and Drive Train
• Engine, drive train, and associated components (internal and external)
are unrestricted
Classing Options, based on local demand:
• A single CAM class for vehicles meeting the above requirements.
• Two classes (CAM-A and CAM-B) split on a model year (e.g., pre-
1973 and 1973-on or pre-1983 and 1983-on).
• Two classes based on body style; muscle car and/or hot rod (alternate
minimum weights may be considered).
• Other methods of subdividing based on local CAM enthusiast requests
