View Full Version : gas tank removal in a 1973 dart!!
How does the filler tube come out of the tank so I can drop the tank. There seems to be a rubber seal at the tank but I cannot get that out or get the filler tube to slip out of the seal!! Thanks
11-03-2013, 10:20 AM
thats cause its like 3 feet long and hermetically sealed to the steel tube after time.
Use lube (WD40) and a scribe or thin screw driver to work the lube into the seal. Then start working the tube back and forth.
racer8188
11-03-2013, 10:59 AM
I've found that spraying PB Blaster around tube and seal works well. It will slide out but may take take some convincing. Good luck
OK thanks. I got it out. I thought maybe it has a flare at the end or something but it did not. What a bitch!
