View Full Version : Hood Pins
ProdigyCustoms
09-03-2005, 09:45 AM
As a general rule I hate hood pins. Even my 150MPH street / drag car does not even have hood pins. HOWEVER, it looks like I will be forced to use hood pins, or reverse the hood because the hood latch will be in the way of the intercooler we have to run. Since I ignore hood pins at all cost, I wonder if anyone has seen anything other then the traditional pin and clevis, or the old twist locks that use a safe key. Either of those are not an option, I would rather not have a hood.
I know you guys surf a lot, wonder what you may have seen?
Camaro Zach
09-03-2005, 10:40 AM
Trip to the junkyard to look for a low profile one? Toyota seems to have pretty compact latches.
MuscleRodz
09-03-2005, 12:04 PM
Oh god no. Do what Charlie did with the MULE and run a latch at each corner. I think they were BMW or Audi pieces. There is some pics on Lat-g somewhere. They were done when they put the new hood on.
Mike
Kenova
09-03-2005, 06:19 PM
Check out the latches in this thread.
https://www.pro-touring.com/forum/showthread.php?t=10225
I've never seen them installed, but if it's done right it should look pretty slick.
Ken
Lesrace82
09-03-2005, 07:03 PM
What about something like these. Couple of guys in town have them on thier cars, dont look too bad. All you see is a little bit of the pin and the little latch taht slides around it.
https://static1.pt-content.com/images/pt/2005/09/mor39010-1.jpg
ProdigyCustoms
09-03-2005, 07:25 PM
Ken
I was actually looking at using those on the hard top boot.
ProdigyCustoms
09-03-2005, 07:26 PM
Those are at least a little less bold.
slowcamaro
09-04-2005, 11:45 AM
and a few supplemental links
http://corner-carvers.com/forums/showthread.php?t=22551&page=2&pp=40&highlight=hood+pin
http://www.skulte.com/gallery/view_album.php?page=1&set_albumName=album01
SatisTraction
09-04-2005, 12:12 PM
why not do some really trick reverse hood pins? have the pin bolted to the hood and pin them through the core support or whatever you have solid?
SatisTraction
09-04-2005, 12:14 PM
oh, i think these look horrible
Modern71
09-04-2005, 09:44 PM
I've seen a few car's (not first gen Camaros), that were retrofitted with the Corvette hood hinges from a 68-82. Its a reverse style latch thats pretty cool, but the problems can cause alot of trouble.
Over at Classic Trucks website, they have an install on an Early F100. The Link is here:
http://www.classictrucksweb.com/tech/0407cl_cpp
It can be a bit of trouble, especially considering the structure of your hood, the people who do it to the older trucks have alot of room to work with under the hood. If you want it to withstand alot of speed and air/wind movement ive never heard of that before.
I guess you could have the pins Lesrace82 posted, powdercoated to body color so they wont show up at all unless someone is really looking...
I guess it all depends on how much you want to avoid hood pins.
Travis B
09-06-2005, 06:10 AM
Frank,
Have you seen the car that roger berman built two years ago! The orange and black 55 conv.! He had a solenoid hooked up in each fender and had a button in the car he hit that button and little pins shot out on each side through little holes in the hood! Pretty trick I would think they could be used as a secondary latches! :dunno:
Also I don't know when you saw the chicayne last but troy actually countersunk 12 point bolts in the hood of it and tightens them down after the hood is latched! :dunno:
CAMAROBOY69
09-06-2005, 06:24 AM
How about making the hood open reverse direction with hydrolic mechanisms. Push a button and it opens automatically then closes automatically. An example would be Steve Sandlin's Inciner8tor. There are pics and videos on lateral-G http://www.lateral-g.org/sandlin/ I saw a 55 with a reverse opening hood about 2 weeks ago. Very very nice set up. No visible locking mechanisms or anything ugly at all. Very trick too.
USAZR1
09-26-2005, 03:16 PM
Charlie,can you or someone else post some photos of the hood latches used on your cars?
Damn True
09-26-2005, 04:26 PM
Why not put a pair of dzus fastners on each corner. Totally flush, you can powdercoat the heads black. Bam, done.
http://www.racerpartswholesale.com/dzus.htm
http://www.kenlowe.com.au/body_hardware.htm
syborg tt
12-02-2006, 07:38 PM
Anyone know where i can get these and possible see more pics of them.
ProTouring442
12-03-2006, 03:56 AM
How about the OEM style like Oldsmobile used? They are made to sit down in a recess in the hood, so you would have to modify the hood. I once used a set on a fiberglass hood for an '85 Monte Carlo, and made the recesses with a set of motorcycle horns, looked very trick. You could powder coat them black. Just a thought.
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442 (http://www.FQuick.com/ProTouring442)
syborg tt
12-03-2006, 12:10 PM
Any chance you have pictures of them. I think i remember them.
Shiny Side Up!
Bill
'72 442 "Inamorata"
syborg tt
12-03-2006, 09:22 PM
okay i found a picture - where can i buy one i have an idea.
Ricoch3T
12-03-2006, 11:15 PM
We use dzus fastners on the race car.. they look nice and work pretty good I think.
ProTouring442
12-04-2006, 03:55 AM
Year one sells them.
Shiny Side Up!
Bill
'72 442 "Inamorata"
kennyd
12-04-2006, 06:57 AM
call ring bros . i talked to mike at sema about the ones he used on the recator mustang , they are killer and he is going to sell set of them . sorry i dont have any photos .
malihoochie
12-04-2006, 11:23 AM
Syborg TT - The pins you asked about are Moroso #39010.
