Formula43wheel
10-29-2013, 03:12 PM
I'm often asked about what type of lug nuts to use on FORMULA 43 wheels. We recommend a 3/4" hex bulge style McGard lug nut as they are made in the USA and exceed OEM standards. These are readily available in chrome or black in the following sizes: 12X1.5mm, 1/2X20, 7/16" (only chrome)
Here's a better description from the McGard website:
"Chrome plated lug nuts lead a tough life. Think about it, harsh elements, nasty corrosive wheel cleaners and lead-foot drivers. Not to mention overzealous impact guns and loose fitting lug wrenches. This kind of treatment destroys ordinary lug nuts which turns even the best looking wheels ugly. Tough Nuts can take the punishment and keep your wheels looking beautiful. Tough Nuts are guaranteed for life not to rust, chip or peel. They are manufactured in the USA to meet or exceed O.E.M. standards for safety and durability. Every lug nut is fully machined from restricted chemistry steel made specifically for McGard and through-hardened for its unsurpassed level of safety. McGard's plating process includes three layers of nickel and one layer of microporous chrome/black producing a superior finish while protecting against rust. Tough Nuts are designed and built for the real world, because life is tough. Bulge Style Cone Seat lug nuts have an extended seating surface that is designed to match the wider seating surface used on some aluminum wheels. For use with steel or aluminum wheels with exposed decorative lug nuts that are tapered at the bottom."
https://static1.pt-content.com/images/pt/2013/10/McGard_zps3471fe3c-1.jpg
We also have open end lug nuts in a variety of styles and can assist in special custom applications for studs and nuts as well.
