View Full Version : which suspension upgrade?
Nomeraka
10-29-2013, 09:35 AM
I have a '98 gmc sierra V6 4.3L and want to lower my truck 2 inches in front and 4 in the back. I have looked at a couple of options that offer lowering kits but would like input as to what works best for handling. Belltech suspension is where I'm leaning towards but still undecided. Recommendations would be appreciated, thanx. I was looking for something with this kind of stance.---->
84373
SLO_Z28
11-03-2013, 09:48 AM
That much in the back is gonna require a notched frame. All of the kits are about the same quality, but Ive gotten good customer service from McGaughys in the past, and seen a bunch of these installed with no problems.
http://www.mcgaughys-suspension.com/chevrolet-c1500-silverado-hd-brakes-1988-1998-4-6-deluxe-drop-kit-part-33137/
Nomeraka
11-04-2013, 06:23 AM
Thank you James, that's very helpful.
astroracer
11-04-2013, 08:48 AM
The stance in your pic will require more drop then 2/4 will give you. Although 2/4 will improve the handling a bit. I would recommend poly bushings in the front control arms and rear springs and add a rear stab bar.
What size tire/wheel are you running?
I did a 4/6 on my '95 with a flip kit in the rear (c-notch required) 2" spindles and 2" springs in the front. Poly bushings throughout and a Hellwig rear bar.
https://static1.pt-content.com/images/pt/2012/11/MVC009Fvi-6.jpg
With 17's and 50 series tires the truck is a slot car. No body lean and good response to steering wheel input. The ride is a bit harsh do to all of the poly but it is worth it in the handling improvement.
Mark
Nomeraka
11-15-2013, 08:56 AM
I still have yet to buy wheels and tires I want to put on my truck. I want the Coys C-55 for my wheels though. I did realize that the drop is going to be more than 2/4. Thank you for your input, I'll look into the poly bushing. Thanx.
Nomer
