View Full Version : Is it necessary to replace the stock 67-69 driveshaft for LS1/T56 swap?
Andrew McBride
10-23-2013, 11:33 AM
I have a stock driveshaft that I was going to have sent out to be shortened at a local driveline shop. I will be running 4:10/12 bolt, T56, and a 350HP LS1. Should I upgrade the driveshaft or is the stock steel one ok? What things should I consider?
Thanks!
BuzzKillian
10-23-2013, 04:15 PM
I just had a new one made... it was less than $300, including the slip yoke. If I can find the picture of my tunnel mod, I'll post it here.
BuzzKillian
10-23-2013, 04:22 PM
I just had a new one made... it was less than $300, including the slip yoke. Here is a link to the trans tunnel mod I did.
https://www.pro-touring.com/threads/98125-T56-Hole-Question?p=985444&highlight=#post985444
GeoffP
10-23-2013, 06:53 PM
I had my stock shaft shortened. The shop that did it only suggested that I not use it with slicks...said otherwise it should be fine as long as I'm not running really high horsepower. Your car and mine are nearly identically configured - LS1 T56 4.11 12 bolt...no worries!
67rally
11-04-2013, 12:30 PM
I had my driveshaft shortened by something like 1 3/4". It was a fairly new aluminum driveshaft, so I wanted to be able to re-use it.
The splines on the old Saginaw's and Muncie's are the same as on the T56, so your old slip yoke will fit the T56, it's just a matter of whether you want to have the driveshaft shortened and rebalanced, or get a new one.
chevy4life
11-04-2013, 01:22 PM
Buzzkillian, where did you have your driveshaft made??? im going to need one for my ls swap into my chevelle this winter.
anthony
TheJDMan
11-04-2013, 02:24 PM
I ordered my driveshaft from Summit but it was built by Strange and as I recall it was about $350 with 1350 series U-joints and T56 slip yoke. You call Summit and they point you to a build sheet that you have to download and fill out then fax it back to them. They then send the build sheet to Strange where they review and accept it. The whole process takes about a week and it comes to your door.
chevy4life
11-04-2013, 07:41 PM
was yours aluminum? i think i am going to go with an aluminum 3.5 in 1350 from shiftmasters. $330
BuzzKillian
11-28-2013, 06:02 PM
anthony
I had it made at Dayton Clutch and Joint, in Dayton, OH. They are only like 30 miles away... so it seemed like a no brainer for me.
I didn't go with aluminum, and I got the 1310 U joints. (Solid) I have no plans of running slicks on this and I'm pretty easy on take offs.(ie. I don't dump the clutch @ high RPM's) SO, use your own judgement on how heavy duty you need to go.
