cactuss4
10-21-2013, 02:49 PM
Soooooo I'm having an internal debate on this.
as I was installing my new Proforged steering package, tie rods etc.etc. I noted that the top of my steering arm had a pretty decent sized indent the the nut would tighten down into the indent. It seems to me that there should be a spacer/shim/washer there, that would sit inside the indent and have the nut sit up above. the washer would provide the required structure so that the ball joint could not move around and the nut would well , torque everything in place.
This picture shows what appears to be a washer of some sort.
84009
Sorry about the blur, didn't know the pictures were that bad!
My steering arm and tie rod end , no washer, and I think there should be one, just seems odd to have the nut drop down inside the arm.
8401084011
Comments, opinions, sizing if you have gone through this yourself, or leave it, it's as designed, do or do not do a washer it won't matter, or?!
Tory
84009
8401084011
Tory
