View Full Version : installed a 200R4 in my 64 F-85 post car
therobski
10-20-2013, 06:58 AM
Guys have a 200R4 in my 64 F-85 pro-touring build and I really would like to keep the 2-speed glide column **** in instead of putting a floor shifter in. I bought Kogul Komponents transmission shift arm connections kit. Can I make this work?
alocker
10-20-2013, 03:46 PM
Yes. I did a PG to 2004R in my Impala. You may have to shorten the shift rod but it will work fine. You will then have to adjust to make sure the park detent on the column is in the right spot. After that, adjust your indicator pointer and reverse/neutral switch so that it works properly.
therobski
10-21-2013, 04:14 AM
Thanks.
