View Full Version : LS3, 430hp upgrade?
osdmike
10-17-2013, 09:54 AM
Hi!
A friend of mine has a LS3 430hp crate engine.
HeŽd like 500+ hp.
What to do?
What kind of ECU is needed? (doesnŽt have one)
Also,... what camshaft would You recommend?
RPM range approx. 1500-6000
The car is used as a daily driver and occasional autocross driving.
Chevelle -66, LS3, T56.
Thanks. Mike.
https://static1.pt-content.com/images/pt/2013/10/24101374311-1.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=374311)
spacepirate
10-17-2013, 09:57 AM
Mast Motorsports cam!
badazz81z28
10-17-2013, 06:45 PM
Did he just buy this? I would have got a 7.0 or a stoked LS3 instead if the power goals were higher.
I suggest CNC port the heads, a healthy cam, and a FAST 102/102 set-up. The ECM can be an OEM type. It will be close to 600FWHP with the right cam.
srh3trinity
10-18-2013, 04:14 AM
Are we talking at the wheels or flywheel? I think you would have to do heads and cam to be at that number at the wheels.
osdmike
10-19-2013, 11:25 AM
Thanks. for the answers.
I think we wait with the camshaft swap for now.
Cold air intake and long tube headers would be a good start.
One question about the ECU.
If we buy the 19258270-GMPP LS3 Controller kit LS376/430.
contains pre-programmed ECU.
Is it possible to reprogram this ECU, if we decide to replace the camshaft to get the 500+HP?
Mike.
Schwartz Performance
10-19-2013, 05:58 PM
Yes you can reprogram it.
71RS/SS396
10-20-2013, 03:53 AM
If this is a daily driver and you are concerned about fuel economy I would buy a magnuson supercharger. You will get the same fuel economy as stock as long as you keep your foot out of it.
badazz81z28
10-20-2013, 07:26 PM
Too many variables with Wheel Hp. I was meaning a tad below 600hp at the crank. Low 500s to the wheels.
