View Full Version : Wilwood 6 piston caliper to rotor alignment?
jlwdvm
10-17-2013, 05:41 AM
I am in the process of mocking up my Wilwood brakes and RideTech Stage 2 front suspension on my 69 Firebird stock sub frame.
I installed the caliper mounting bracket and rotor on the passenger side and torqued everything down. I think I am using the right spacers according to the directions. I tried to slide the brake pads in and I think I have a problem. the inside pad slides in with room to spare, and I can't even start to slide in the outside pad. I am using RideTech spindles along with the rest of their kit. Does the caliper mounting bracket need to be shimmed outward to get even spacing for the brake pads? I called Wilwood yesterday and left a voicemail...no reply yet.83783This is what the brake kit looks like.
rickpaw
10-17-2013, 05:48 AM
Yes, you need to shim the caliper out in order to center it over the rotor. I think Wilwood includes shims to do just that.
cactuss4
10-17-2013, 08:31 AM
Ya there are spacers/shims between the caliper and the bracket, which pulls the caliper inwards, centering over the rotor.
Tory
jlwdvm
10-17-2013, 09:10 AM
The way the calipers mount to the bracket there is only up and down adjustment to get the pads adjusted over the rotors. The in-out adjustment has to come from moving the caliper mounting bracket in-out I guess.
