View Full Version : Pedal assembly 66 Chevelle, options, restore stock setup?
cactuss4
10-15-2013, 10:11 AM
Wondered if there was an aftermarket pedal assembly that would bolt into a 66 Chevelle available (I'm not great with custom fab stuff, but I can bolt almost anything in :)). Or does it make more sense to pull the stock pedals, sand blast, powdercoat/paint or whatever and use those?
Wilwood has some options, but nothing looks to be a bolt in (that I've been able to find). And pedals on ebay are all as rough as mine and are pretty costly. So maybe it's downtime, yank , blast, clean up, replace springs and other things that can be replaced and reinstall?
Tory
cactuss4
10-15-2013, 12:14 PM
w0w those are sexy but list of almost $700.. That's a bit steep, with other things needing to be done first. I'll keep those in mind and may consider when the sheet metal is done and or the entire car is blasted and painted so I'm not seeing funny colors of orange, red, brown when I look under the dash
Thanks!
