View Full Version : Delrin leaf spring bushings
Brandon Miller
09-01-2005, 10:07 AM
Would Delrin leaf spring bushings be a good idea for a daily driver with occasional road coursing or should I stick with polyurethane?
79T/Aman
09-01-2005, 02:47 PM
neither... rubber!
chicane67
09-01-2005, 06:57 PM
Ive been running GW's del-a-lums for 10+ plus years. The chassis has seen the street as a daily driver for most of that and double duty at the track as well. I would run them if you have the means.
And unless your going to run a pan-hard bar in the rear suspension, or some other lateral locator, rubber isnt going to cut it. I would also run the other way from using poly.......
Brandon Miller
09-01-2005, 08:02 PM
The Delrin bushings would not be a problem to acquire since I can turn them out on the CNC lathe at the shop. I'm just trying to see if it's feasible to run them over polyurethane bushings.
