View Full Version : AGR power steering box
32deucecoupe
10-04-2013, 02:53 PM
Does the AGR 492117 steering box work with a 2004 GTO LS1 pump? Do I need custom lines made?
Z06vet
10-04-2013, 03:15 PM
I run the IROC box with the stock LS1 pump with very good feel. I cut the ends off the LS1 lines where the hardline meets the ruuber hose. I then had a new rubber line made to length with the correct fitting. Is the agr box metric threads? IF the GTO lines will reach and are bent correctly, you may be able to use them. Same goes for the return. You can also get adapter fittings to go from metric to std if needed.
Scott
32deucecoupe
10-04-2013, 04:03 PM
Thanks for the info, haven't bought the box yet, what year IROC box are you using?
Z06vet
10-04-2013, 07:35 PM
I used 90 Iroc box. I havent used the AGR, it may be a better box. Scott
