View Full Version : LS2/LS3 -6 speed install in a G Body- Need Serpentine belt install info
Rwolf15241
10-04-2013, 01:52 PM
I have a 1986 El Camino, looking to install a LS2/LS3 -6 speed - Need Serpentine belt install info -Which FACTORY brackets are the best to use??? Corvette looks like the best solution !! What do you guys think??
Thanks RW
Z06vet
10-04-2013, 03:21 PM
Corvette or F-body I would think. Maybe some of the Monte SS guys can chime in on what fits best. There are plenty of elcos and montes with LSx motors, somene has had to have tried both. You can use the stock serp belt if using stock accessories. If you plan to run AC, (Kwik bracket or Holley bracket) both give you the correct belt to run. Scott
cmac06
10-04-2013, 08:10 PM
Corvette acc drive. I just triedf-body, and alt hits steering.
CruizinKev
10-05-2013, 01:00 AM
x2 on Corvette drive :twothumbs
Samckitt
10-05-2013, 04:39 AM
I have Vette setup using the Holley AC bracket.
EFI69Cam
10-05-2013, 01:44 PM
Mines not a g-body but I can vouch for the Vette setup with Holley AC bracket. It puts all the accessories up high and out of the way.
Also the quality of the holley stuff is top notch.
Samckitt
10-05-2013, 06:20 PM
Here is the brackets I have, not my engine.
Rwolf15241
10-06-2013, 05:10 PM
I like the set up, I can keep my A/C hoses short
Samckitt
10-07-2013, 06:15 AM
I bought the compressor pictured above, before I found out about the Sanden 4864 compressor.
http://store.sanden.com/index.php/4864.html
It will mount on the same bracket, but has GM style fittings on it. There is a guy using this compressor in his El Camino (TPI motor) & uses 91 F body hoses, condenser & all works.
Not sure if it will work in my case with 1" set back mounts & an LS motor. Here is where my compressor sets with the LS motor, 1" set back plates & Holley bracket:
Here is his pic of the compressor in the El Camino. Looks like same hoses would work for us as well:
https://static1.pt-content.com/images/pt/2013/10/CIMG3571-1.jpg
Samckitt
10-07-2013, 06:37 AM
My only concern looking at it is this compressor will be rotated 45 degrees using the Holley bracket, so not sure how the hoses will fit.
Rwolf15241
10-10-2013, 01:42 AM
I was planning on the Dirty Dingo mts, with 2 inches of travel
PS Thanks for the input, keep it coming
Samckitt
10-10-2013, 04:33 AM
I am using Trans Dapt 1" setback mounts.
Rwolf15241
10-10-2013, 04:18 PM
Since you did the swap, did you use the factory gauges??
Samckitt
10-10-2013, 04:43 PM
Haven't got it started yet, but yes I am using stock gauges. Oil pressure sender in oil pan fitting, water temp from a modified sending unit machined to fit in the LS3 head. Tach signal has to be programmed as the proper output to run the Monte tach. Amp I haven't looked at yet, but shouldn't be a problem.
Monte_ExpreSS
10-10-2013, 06:47 PM
Corvette brackets/acc fit very good. I also use the Holley bracket but with a r4 style compressor & the 91 Camaro hoses.
https://static1.pt-content.com/images/noimg.gif[/quote]
Rwolf15241
10-12-2013, 03:49 PM
great pics, what is the benefits of using each type of A/C compressor
Rwolf15241
10-13-2013, 04:41 AM
What A/C condeser are you using
Samckitt
10-13-2013, 05:13 AM
I read that a guy went through 3 of the R4 compressors (using R134) in 6 years, then switched a sanden compressor made for R134. With the Sanden compressor he can still use 91 F body hoses & condenser on the G body. I went with a different Sanden compressor before knowing about this one that works with stock 91 hoses.
Rwolf15241
10-14-2013, 10:55 AM
Does the F Body A/C Lines come out on the passenger side ??
Samckitt
10-14-2013, 11:27 AM
Does the F Body Lines come out on the passenger side ??
Yep.
Rwolf15241
10-14-2013, 11:30 AM
I really like your install Very Clean!!, I hope I can get mine to look that GOOD !!
Samckitt
10-14-2013, 11:49 AM
91 F body.
Rwolf15241
11-09-2013, 08:00 PM
OK, question for you guys with the LS motors & the 6 speeds trans??? in relations to the stock trans mount. how much different is the 6 speed mounting point from the automatic trans ??
Thanks RW
Rwolf15241
11-09-2013, 08:03 PM
Did you make that dual air intake??? ,that is sweat!!
