View Full Version : Beetle Rod from AFTERMATH
Aftermath Hotrods
10-02-2013, 07:11 AM
This build is going to happen pretty quick. Build started some time ago and I've been asked by a few buddies to post progress here. I hope you like.
8310083101Yes its possible to bring you next project home in the back of your shop truck.
driveit
10-02-2013, 07:16 AM
Awesome, but you should have titled that Bed Bug!
Aftermath Hotrods
10-02-2013, 07:17 AM
83103
Just a quick survey of the starting point before it gets chopped into a bunch of little pieces.
83104
Aftermath Hotrods
10-02-2013, 07:19 AM
Good one. That didn't even cross my mind
Aftermath Hotrods
10-02-2013, 07:21 AM
And now we get into the fun part. I was shooting for about a 4.5" chop.831058310683107
Aftermath Hotrods
10-02-2013, 07:23 AM
I always feel better when the roof goes back on.831088310983110
Aftermath Hotrods
10-02-2013, 07:34 AM
If your a die hard VW guy you probably should have stopped viewing this thread already. If by chance your still here, now would be a good time to stop.
Started on the chassis. Its completely tube with the exception of the main frame spars that run right inside the doors.
83111
This shot kinda give you an idea of where this build is headed
83112
4 link and rear frame section
8311383114
The start of the cage. Keep in mind that this thing is being built on the cheap. Don't crucify me. Most of the materials are shop scrap and being pieced together
Aftermath Hotrods
10-02-2013, 07:42 AM
Engine mock up. It's gonna be pretty tight.
83115
Another one head on
83116
Aftermath Hotrods
10-02-2013, 07:43 AM
I have to apologize if some of this seems a little out of order. I have a ton of pics and I'm trying to catch you guys up.
Aftermath Hotrods
10-02-2013, 07:48 AM
This is basically the look I was going for.
83117
Here is another one. It's stretched 8" out in the front and about 2" back (from factory VW) for a wheel base of 105"
83118
Aftermath Hotrods
10-02-2013, 07:53 AM
Getting into the interior... After the chop there really wasn't a whole lot of room left. I'm 6'1" and about 200 pounds. The goal was to put me in it in a reasonably comfortable position. Safety is paramount in my mind. I hate seeing this type of car that is virtually impossible to drive.
83119
83120
83121
83122
19,69camaro
10-02-2013, 08:05 AM
Very cool! That chop made all the difference in terms of attitude
Zachalanche
10-02-2013, 08:21 AM
Love it. what wheels are those?
Aftermath Hotrods
10-02-2013, 09:05 AM
All four wheels are 15x10 D-window steels. Tires are 295/50-15's all the way around. The target weight for this thing was about 1800 pounds so I wasn't really concerned with the extra weight of the steel wheel.
Z06killinSBF
10-02-2013, 09:38 AM
Nice!
No speedo? I guess if you're getting passed you aren't going fast enough...
MSTSFabbed
10-02-2013, 12:09 PM
HECK. YES!! I've wanted to do this with a mid mounted liter bike engine for a couple years now. Keep us posted!
Aftermath Hotrods
Ya I kinda ran out of room for a speedo. Besides, I usually don't care how fast I'm going. Go with traffic and you'll be fine...probably.
Aftermath Hotrods
10-02-2013, 12:21 PM
Radiator had to go in the back because of the lack of room up front. Mock up had me a questioning whether or not this was going to work.
83124
Once it was all said and done it came out OK. The cooling system contains a little more than 6 gallons of fluid
83125
Cooling lines and a few shots of how cramped the back end became.
83129
83130
83131
Aftermath Hotrods
10-02-2013, 12:29 PM
Front suspension consists of a 2" drop mustang II coil and custom made A-arms. I used a power pinto rack and then wound up not having room for the pump. I've contemplated running the power steering pump off of the drive shaft but haven't gotten there yet. My target with was 73.5" for a track width. I wound up about a quarter inch wider. Wasn't a big enough deal for me to change it. The next time I do a-arms I'm going to change the design. I didn't leave myself a lot of room for alignment adjustment.
83133
A 2500 pound air bag will find its way in there pretty soon.
83135
83136
Aftermath Hotrods
10-02-2013, 01:03 PM
Here are a few random shots of the dirt track style headers that I wound up working so well in my cramped engine compartment
83139
83140
83141
83142
The original idea was to use just this turn down with an internal baffle as the complete exhaust system. It wound up being entirely too too loud and blew all of the exhaust into my face. I later fabricated a corvette style side pipe exhaust system that required manipulating the bottom of the door so that it would open over the exhaust.
83143
Looks like this. Door opens over it. Quieted it down enough to keep the sound police happy most of the time and put all of the fumes behind me. The pipes are aimed right into your window when we're sitting at a light. Cheap trick, I know.
monteboy84
10-02-2013, 01:42 PM
I'd like to see a manual trans in it, but the whole thing is so horrendously filthy and evil that I'm still in love.
rustomatic
10-02-2013, 01:56 PM
To some degree, I think all of us, even the chronic car-washers, think this thing is awesome, if not only for the level of committed social irresponsibility inherent in every part of the design. Let's see a Metallica sticker somewhere on that thing!
Aftermath Hotrods
10-02-2013, 06:31 PM
Thanks I really appreciate the "horrendously filthy and evil" comment. That was the goal.
Aftermath Hotrods
10-02-2013, 06:39 PM
Here are a few more random ones. I've been trying to keep all of these in order but I've totally lost track of what time frame I was at when they were taken. The steering wheel is made out of three BOSS 302 connecting rods (sorry ford guys) and a Mercury outboard forward pinion. Pinto rack and pinion and a chopped up sway bar. I've caught a lot of flack about cutting up the sway bar and welding it back together from all the "know it all's" at car shows but I've been driving the piss out of this thing for a while and its seems to be doing it's job and holding up just fine.
83154
83155
83156
83157
srh3trinity
10-02-2013, 06:56 PM
I always wanted to see one of these with an upright grill or a cool tractor grill. You should look up satan's lady bug on here.
Aftermath Hotrods
10-02-2013, 07:03 PM
I think I saw satins lady but on here a while back. It's truly a work of art. My goal here didn't involve beauty in any sense of the word. I kinda like the simplicity of mock up... tighten up and drive. I can do pretty and polished every once in a while but sometimes raw steel and rough around the edges is just so much fun.
MSTSFabbed
10-03-2013, 03:37 AM
Dude your little transmission impaler spike scares the crap out me!! Point that thing AWAY from your leg haha!
I love it. So much awesome.
Aftermath Hotrods
10-03-2013, 05:28 AM
Ya the spike was kinda a cool idea until i put the drivers seat in. I should have made it go towards the passenger, no one ever wants to ride with me??? Anyway, needless to say the spike was dulled extensively.
85coupe50
10-03-2013, 06:35 AM
Badass beetle.
Aftermath Hotrods
10-03-2013, 06:57 AM
Thanks man I appreciate it.
Aftermath Hotrods
10-03-2013, 12:13 PM
Ran into issues with battery placement. It was either behind the passengers head with a very small battery or between the passengers legs with a regular sized optima. Some potential passengers might have had a problem spreading their legs for a big piece of plastic (the battery guys, come on) so I went behind the head with a mount from ballistic fab. Its the same battery that starts a Prius engine. That's as close as I can get to going green.
83193
No place for a battery means serious problems with mounting a compressor and tank for the bags. I found a 1.5 gallon tank and a Viair compressor that sorta sticks up out of the back window area. The tank will allow me to get to ride height one time without running the compressor. Its a compromise but it works. Manual valves.
83194
Aftermath Hotrods
10-03-2013, 05:46 PM
A cobra gas filler cap left over from another project found its way onto the roof. For some reason I get funny looks when I pump gas into the top of the car.
83204
Aftermath Hotrods
10-03-2013, 05:54 PM
I figured that at some point the hood would need to go back on. It wound up turning into a lift off style hood. Two pins push into the cowl and then the factory latch catches at the front. The goal initially was to keep everything under the hood but that's usually tough to accomplish when putting a V8 in what was designed to be a trunk and impossible in this situation.
83205
Plan B was to make the hood look as factory as possible. I'm still not satisfied and usually drive around without the hood.
83206
83207
Aftermath Hotrods
10-04-2013, 11:41 AM
When you need a break from the daily grind there's nothing like picking up the engraver and going to town.
83228
Aftermath Hotrods
10-06-2013, 07:52 PM
Lights, wiring, throttle cable (or rod), steering shaft, bleed the brakes and we're off. On it's maiden voyage I received a couple thumbs and a couple fingers... I wouldn't have it any other way.
83373
I'll work on some video in the coming days.
Aftermath Hotrods
10-07-2013, 08:57 PM
Hey guys, this thing went up on the block tonight. Ebay auction number 190924190424. Spread the word for me to anyone who wants a true one of a kind. Thanks.
NickyP
01-02-2018, 12:31 PM
Did you go with US Wheel for the steelies? Just curious they look great!
TonyHuntimer
01-03-2018, 12:06 AM
Cool way to chop the top! Looks like it's going to be a fun car to drive.
