View Full Version : Squeaky Leaf Springs
68Formula
09-27-2013, 01:58 AM
The car had been sitting for some time before I was able to get back to work on it. I did a rearend swap, and while I was at it, I removed a leaf (it was a 5 leaf, too stiff, and sat too high.) Now when I go over bumps, I sound like I"m in an Amish big block buggy. The springs sound awful. Don't know if it's something I did, or because it was sitting for so long.
Here's what I did. Removed the front bracket (to drop the spring out of the way for the rear swap). Pulled the spring pack bolt. Removed the bottom leaf. Reassembled. I also had started to unbolt the rear eyelet, but due to access getting the bolt out, decided not too.
My question is, did I over tighten something? Not tighten it enough? Is it just because it was sitting for so long? The car is a convertible, so it's especially noticeable and annoying. Really don't want to tear everything apart again, unless I absolutely have to.
68Formula
09-27-2013, 12:12 PM
Over 40 views and nothing?
Skip Fix
09-29-2013, 08:30 AM
First question -what kind fo spring eye bushings? Urethane?
Many springs have a little plastic "cushion" on the end of the leaves to help them slide and not make noise.
1966longroof
09-29-2013, 03:10 PM
Lube everything.
09-29-2013, 03:24 PM
Thats because it uses the same suspension as an amish buggy.
seriously, did you remove any cusions when you removed the leaf. Was there a gap left between the shackle clamps?
Look for tell tales like rust spots. Lube the contact points with a spray grease and keep trying.
68Formula
09-29-2013, 03:52 PM
Thanks for the replies!
I believe the eye bushings are poly. No zerk fittings on them though. Is there a way to grease them?
The isolators between springs are still there. I only removed the bottom one, which did not have the isolators.
Unfortunately the Bilstein shocks I installed are so stiff I can't even flex the suspension to see if it's the springs themselves or the bushings.
