birdsandbowties
09-25-2013, 09:01 AM
checking interest in this car to see if anyone would want it , i have a all black 2000 ram air formula with ls1 5.7 and 6 speed, it has a choppy hot cam,ls6 intake, long tube headers that are coated, 4 wheel disc brakes with drilled and slotted rotors, 18inch polished c-5 vette wheels on back and 17 inch on front with bald tires, back tires have about 30k on them, still in good shape though, we drive this car everyday for the last 3 1/2 years with no issues, but it needs some work, the trans will need to be rebuilt as 4th gear has vibration to it and seems like the syncro's are worn out, but it does have 235,000 on it ! the interior is in good shape and not ripped up, the pass seat has a spot where the stitching is loose but other than that its in good shape, a/c blows cold and heat works great , posi with 3.42 gears, aluminum driveshaft etc etc
this would be a good parts car to build a camaro or ? out of , the motor sounds very good and tons of power, i have a clear title to it , i just dont want to put any money into it , i traded for it a long time ago and wasnt such a good trade on my end :( so i am going to try to get ome of my $ back and take my losses and move on, this could be used as a parts car to build one and sell off the stuff you dont use, the hood alone is a gm and worth 800.00 alone ( ram air), console is in good shape and lid works fine , if you may be intersted in it please give me a call and we can talk about it , i want to get at least 5000.00 for it since it has so many good parts that can be used to build another hot rod , Jim 850-382-7125
