View Full Version : LowNfast Chevelle 2.0 - 408/6L80/Turbo
LowNfast
09-24-2013, 05:34 PM
Just getting started on Chevelle 2.0, this will be a ground up build using lessons learned here and from personal experience. I will still have my 71 Chevelle as a daily/fun car.
You can check it out here- http://m.ls1tech.com/forums/showthread.php?t=1490158
Follow along, I'll be sure to update as I go.
I found this 72 Chevelle on Craigslist, it's a basket case but the body is very solid and mostly ready for paint. I have the build sheet with the car, it was orange flame, white vinyl top, white interior from the factory. It was sold locally in Texas where I live and has been here ever since.
https://static1.pt-content.com/images/pt/2013/09/A16F360DE86C46138297970882B7C94A11440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/4C9CE1795CA549ACB877C72E5244138311440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/500DDBDBF6FB451184408EE68AC4C70211440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/6CF0DAA09EA9478F8A7A57656161934411440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/77B41F78E27B40BCAC8A5A3BEF3EC0AA11440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/7854E55BDC4D4204A5A6BC82B97885CF11440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/3BBA464C9AEC40C9AA95AB414CBC3E9611440000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/6A722DF4CEC64221969A9F188E55137011440000-1.jpg
LowNfast
09-25-2013, 08:01 PM
Started on the fire wall and got the Trans tunnel situated to fit the 6L80.
https://static1.pt-content.com/images/pt/2013/09/CC08C327F338416CBB3673B3F0CE3BA212980000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/415E4DB35875414EAC91A46BE07F405612980000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/305EA07FDF524C7FBE5952C11542849312980000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/DC5679B66C4946D79C1BEE435CE3B65A12980000-1.jpg
Now I can prep the floor for lizard skin. Hope to have it done this weekend.
andrewb70
09-26-2013, 05:23 AM
Looks like a solid car to start with...
I would really pay very careful attention to the driveline angles. You certainly made plenty of room for the actual transmission, but if you plan to lower the car, then you may want to think about raising the driveshaft tunnel 2-3 inches going all the way back. This will give you plenty of room to raise the back of the engine, which is what is required to maintain optimal u-joint operating angles.
BLACKLIST
09-26-2013, 05:28 AM
nice chevelle build. wish my 71 had a nice shell like yours to start with.
Josh@Ridetech
09-26-2013, 05:44 AM
Very cool. Looks like a good car to work with!
David LaBuda
09-26-2013, 08:56 AM
I agree about raising the driveshaft tunnel. Now is the time to do it. Even if you don't need the extra clearance right now, it may prevent a giant headache in the future.
Steve Chryssos
09-26-2013, 10:02 AM
Being it's a 6L, you can also implement a 2 piece driveshaft with a carrier bearing in the middle. That seems so unconventional on a muscle car, but it's actually a simple and great way to have the best of both worlds. And yup, they make slip yoke style carrier bearings.
BLACKLIST
09-26-2013, 10:09 AM
just spotted another 71 in the background... Must Be Nice!!
LowNfast
09-27-2013, 11:55 AM
Thanks Blacklist..
The 71.... I built over the past 2 yrs. It did power tour after just three weeks on the road. So far I have almost 6000 miles on her. Daily drive it to work, LY6 cam only /T56 .. I love it.
https://static1.pt-content.com/images/pt/2013/09/76923A16F762414399B6CC9D45772DBD11200000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/null_zps12df0f9d-1.jpg
https://static1.pt-content.com/images/pt/2013/09/null_zps4016295c-1.jpg
I don't have a thread on here for the 71 build but I do on ls1tech.. The link is in my first post.
LowNfast
09-27-2013, 12:05 PM
I've been thru this already actually, used your thread as research on the cv type shaft, very cool parts. I just can't bring myself to spend $1400 on a drive shaft. My 71 is on 2 inch drop springs and has 3.5 inch drive shaft and clears the body if it bottoms out ... Just not by much.
LowNfast
09-27-2013, 12:14 PM
I decided to leave the blower/vent hole exposed. I like routing my ac/heater lines for the vintage air thru the fender. I still need to do some more work to clean things up but needed every thing in self etch primer to prevent rust.
https://static1.pt-content.com/images/pt/2013/09/0895142F07734541B4C6D8992FB41D6210860000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/BDCCB0CB80E54BA68B0872F67885ADEB11200000-1.jpg
Cleaned up what little surface rust I could find on the floor pans and sprayed some primer.
https://static1.pt-content.com/images/pt/2013/09/7822F85011DD4E7ABC33E786F6D64C2211200000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/A96A9D1090494EFA99A022E45220919A11200000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/2417699FDC0C485AB3EF6DCE0F321B3E11200000-1.jpg
CruizinKev
09-30-2013, 10:14 AM
looks good so far!
LowNfast
10-01-2013, 04:27 PM
Picked up a parts car to rob the front end from. The dash has no cracks and fits perfect. The story I got was that the car was garaged up until 4 years ago. Some purists may not approve but I love the 70 front end!
https://static1.pt-content.com/images/pt/2013/10/57A984BA5B5847A6B2442D119377675D51250000-1.jpg
Chevelles hangin out.
https://static1.pt-content.com/images/pt/2013/10/8CA26A7F86B04019A652AF45C0255BD251250000-1.jpg
LowNfast
10-13-2013, 06:11 PM
Started tearing down the 70 for its parts. I'm impressed at the factory panel fit.
I'm either going to put my 72 front clip and sell the 70 or part it out. Just not sure yet. Here are a few pics of the car.
https://static1.pt-content.com/images/pt/2013/10/1A5F43B633F346589756ECF96137F70E17290000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/F80BD9BD3FDC4D56A6AC1EF5A2CF7B8B17290000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/A3E5F9475E1F430B932AA18A037450FF17290000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/2BC8AF04BB474DBAA8B2D8CBC1DB515F17290000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/E80ED47C4C94489F9410C1EBE4C7F36217290000-1.jpg
Z06killinSBF
10-14-2013, 06:50 AM
Hey good to see you over herre, I followed the build of the black one one dfwminis. This should be cool when done.
LowFast
10-14-2013, 07:47 AM
I am in, if for any reason the screen name. :cheers:
LowNfast
10-14-2013, 10:57 AM
Z06killin, This site is much better than dfwminis!
LowFast.. I see what you did there lol
Z06killinSBF
10-14-2013, 11:58 AM
Ya, people actually post over here!
DYNODANNY
10-14-2013, 12:29 PM
Good start up.
bonecrrusher
10-14-2013, 12:39 PM
Nice car - like the pics at the NC sign.
LowNfast
10-20-2013, 08:16 AM
I don't think the wife will be happy but I found a place to keep the 70 front clip. It's in good shape. Just a little rust on the bottom of the passenger fender. I lower patch should take of it.
https://static1.pt-content.com/images/pt/2013/10/5FBCCD5CE055408AB63B8B6573D1C12340530000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/6783CD40379844699D283F3076BC387940530000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/7800768D83494D88BEFFEC1B23FCBE3640530000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/DDC3288BC6024425A5FE6E8E0CB364E140530000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/6EEE16272879452D8FC07FD9B762E09040530000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/3E2A5EE92AFA41489B065B2A93AD39E340530000-1.jpg
This 70 came with plastic inner fender, I knew it was an option but never have seen them until now. Ill get the parts cleaned up so I can test fit every thing on the 72.
LowNfast
10-20-2013, 06:55 PM
The 70 is ready to sell with the 72 front end on it. It's on CL for $1400 obo.
https://static1.pt-content.com/images/pt/2013/10/17347355D07643BFBF74F6F1CDCD233932200000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/EFB1219F17164A3492874C453437C29332200000-1.jpg
https://static1.pt-content.com/images/pt/2013/10/418BA4F5CAD34BC2B21BF44D1B18788732200000-1.jpg
LowNfast
01-01-2014, 08:17 PM
Starting to collect parts now that the holidays are over.
Drum spindles and hubs from a friends el camino, C5 brakes and wheels. I don't plan to keep the wheels.
https://static1.pt-content.com/images/pt/2014/01/477403AEB67144E7AF99046415090FCB_zpswcfu-1.jpg (http://s101.photobucket.com/user/lownfastsonoma/media/477403AE-B671-44E7-AF99-046415090FCB_zpswcfuvt02.jpg.html)
LowNfast
01-22-2014, 05:44 PM
Picked up my 6L90e from a 2013 silverado 2500 with 2 miles on it! Was damaged in transport to the dealer.
https://static1.pt-content.com/images/pt/2014/01/30C9C7CA150844DB9E98FA8086C2A51D_zpszyee-1.jpg (http://s101.photobucket.com/user/lownfastsonoma/media/30C9C7CA-1508-44DB-9E98-FA8086C2A51D_zpszyeepxjy.jpg.html)
LowNfast
06-06-2014, 09:35 AM
No update on this car, sorry guys. Ive been working on the black 71 doing body work and now its at the paint shop. Once i get the trim and stuff back on, Ill get going in this again.
LowNfast
11-10-2014, 07:50 PM
haven't done much with this car, after the 6 month fight to get the 71 painted, this car has been put in the barn at my grandfathers place until further notice.
https://static1.pt-content.com/images/pt/2014/11/F02884A8FA0E4103B4B78D50A614107B_zpscwql-1.jpg
https://static1.pt-content.com/images/pt/2014/11/38CBE1EE575E4DE38174966709AFCD04_zpsdham-1.jpg
FlatWhiteLark
06-13-2016, 05:42 PM
Have you been able to do any more to this in the last 6 months are is it still hanging out?
LowNfast
08-22-2016, 02:19 PM
I've managed to rob some parts from it, but that's about it.
