View Full Version : Th400 swappers use this!
DCx
09-24-2013, 02:05 AM
Look up this part number in any search engine:
Apt z270 flexplate
Its a brand new 6.0 flat flexplate, crank spacer, and bolts for around $50-$65. Much cheaper than using the over priced gm spacer and bolts with a curved ls1 or 5.3 flexplate! It allows for the use of a 11.5" th400 converter, not the small th350 10.75 converter bolt circle.
Toddoky
09-24-2013, 07:01 AM
Apt z270 flexplate
Good info indeed. If you need a crossmember for mounting a TH400 behind an LS engine, the new Hooker T56 crossmember has been validated to work well for that purpose by merely installing a 1-1/4" tall spacer block between the crossmember and the trans mount. Here's a photo of the install...
DCx
09-25-2013, 12:42 AM
https://static1.pt-content.com/images/pt/2013/09/830D1F77761E446E81E5E67146357E1112052000-1.jpg
https://static1.pt-content.com/images/pt/2013/09/9760B48618124087B6A52F2DC9F5D33512052000-1.jpg
