View Full Version : 9 inch pinion bearing
cwylie
09-23-2013, 01:44 PM
I was working on setting up my gears in my rear end and I went to install the inner pinion bearing and it just slid on no press needed. Is that normal? The bearings are new but the gears were lightly used.
sccacuda
09-23-2013, 01:46 PM
Do you have a Daytona pinion? Sounds like you have Daytona bearings for a regular 9" pinion.
sccacuda
09-23-2013, 01:51 PM
BTW - No, that's not normal. The bearing needs to be a press fit.
cwylie
09-23-2013, 06:58 PM
Yes its a daytona pinion support. Is the daytona bearing a little larger inside diameter? I know the od is larger.
cwylie
09-24-2013, 05:58 AM
Well I just pulled it apart and the bearing is seated on there now. I ran the pinion nut down on yoke but had not set the preload yet so I was able to pull it apart. I would have had to press the bearing off as it was not coming off by hand.
