View Full Version : Fidanza aluminum flywheel small block or big block chevy
Evldoer
09-13-2013, 05:04 PM
I have a good used Fidanza aluminum flywheel that came off an internally balanced big block Chevy engine. It will work on an internally balanced small block also. 153 tooth ring gear. I used this with a ZF 6 speed trans and a ceramic disc clutch.
Price is 200$ shipped
andrewb70
09-13-2013, 05:33 PM
I am pretty sure that the bolt pattern or the crank register is different between a SBC and BBC.
MarkM66
09-14-2013, 05:07 AM
They're the same.
Bad Bowtie
09-14-2013, 05:25 AM
Andrew,
I think the SBC & BBC bolt pattern and crank register are the same on early model motors, but there is a difference when you switch over to the one piece rear main seal style crank. It all gets so confusing. GEN I , GEN II , MARK IV, GEN VI, LS this LS that. :hmm: :)
BB
andrewb70
09-14-2013, 05:56 AM
Thanks for the clarification. I didn't mean to muddy up the thread. My apologies.
Evldoer
09-14-2013, 07:40 AM
Yes, this flywheel will not work with the new one piece rear main seals. It will only work on the big and small blocs with a 2 piece rear main seal.
Nova70
11-04-2013, 02:32 AM
Still have the flywheel?
Evldoer
11-04-2013, 10:15 PM
Yes it is still available
Evldoer
11-10-2013, 09:22 PM
Flywheel was sold today.
