derekf
09-12-2013, 05:21 PM
Yes, this is another one of those threads.
I've got a 69 El Camino. I've had it since 1990, and before that it was my father's.. I've got all the receipts for the car back to '81, and probably older than that (81 was the earliest I quickly found). It's got a half million miles on it, 300k of which I did. I'm in the process of an LS conversion for it; motor and tranny are installed, upgraded suspension and brakes are done.
It's got issues, not the least of which is that I've had it torn down for the last six years. It's an Indiana car, and it lived through at least a few Indiana winters with Hoosier road salt. It's got rust. I started in the front and I worked back - fenders are good, cowl and firewall and dashtop issues are fixed, floor is partially fixed. I've got back-of-cab, bed, (small)fender-bottoms, package tray, and outer wheelhouses left to do. That kind of rust repair doesn't bother me so much.
It's got (maybe) frame issues. Not too long after I got it, the rear LCA mount on the driver's side tore free. I had it welded back together. About 15 years ago, the same occurred on the pass side. I had that welded back together too. (They did it poorly, I've cut it out and moved it to the right spot). Somewhere in there I let someone else drive the car, and they hit a Buick; the front frame horn may be a little bent. The integrity of the frame worries me a little bit, but I had intended to add some reinforcements to that mount on both sides. My skill with a welder worries me a little there too.
These are the issues I've known about... and then there's the little things that become large problems.
It's got an aftermarket sunroof. I don't know when it was installed. I don't like the sunroof, but I accept it because it's already there. I know the sunroof needs to come out to repaint, and I know that removing the sunroof will destroy the weatherstrip.
The Internet says the weatherstrip is no longer available, anywhere.
So: I reckon my options are:
Replace the roof skin. I do not have faith in my ability to do this correctly.
Buy a bigger sunroof. Ugh.
Find another 69 El Camino body/frame that are in better shape, and move everything over.
Give up on El Caminos and find an equivalent 68-70 Chevelle to move everything over to.
Move all the LS and suspension bits over to my 65 Chevelle convertible (some parts won't fit the early A bodies)
I don't have a lot of money (actually, I have about none) so I don't think I'm in a position to hire someone to do the roof replacement. Buying a different car to bolt everything to would require selling the Chevelle first. The 65 is a non-AC car so won't really work well as a daily driver, plus convertibles in the summer here can be unpleasant.
So - PT folks - what do you think?
