View Full Version : New Synthetic 2-Stroke Injector Oil from AMSOIL
AMSOILGUY
09-11-2013, 04:00 PM
https://static1.pt-content.com/images/pt/2013/09/AIO-1.jpg
AMSOIL Synthetic 2-Stroke Injector Oil reduces wear and maximizes engine life. Its high lubricity and reliable film strength help protect against piston scuffing and bearing wear.
Package sizes include:
Quart Bottle
1-Gallon Bottle
16-Gallon Keg
30-Gallon Drum
55-Gallon Drum
275-Gallon Tote
Strenuous conditions define the normal operating environments of snowmobiles and boats. Without the right lubrication, two-stroke snowmobile engines and outboard motors run hotter, accumulate deposits and suffer a reduction in performance. AMSOIL Synthetic 2-Stroke Injector Oil offers the convenience of one formula for the tough conditions of all two-stroke recreational equipment requiring NMMA TC-W3 and API TC two-stroke oil. It’s tested and proven to minimize wear and deposits that can damage internal components. AMSOIL Synthetic 2-Stroke Injector Oil provides quality and affordability for cost-conscious enthusiasts who want the benefits of synthetic two-stroke oil.
Wear Protection
Engine Cleanliness
AMSOIL Injector Oil is clean burning. It is fortified with high-temperature detergent and dispersant additives and naturally resists harmful deposits that cause ring-sticking, ring-jacking and exhaust power valve sticking. AMSOIL Injector Oil is ideal for direct-injection outboard motors, snowmobiles and personal watercraft (PWC).
Cold-Temperature Performance
AMSOIL Injector Oil provides cold-temperature fluidity with a pour point lower than -60°F. Rapid oil flow on cold starts ensures oil reaches vital components quickly and helps prevent damaging, dry starts.
NMMA TC-W3 API TC
Ideal for outboard motors and snowmobiles
Protects against rust and wear
Controls deposits
<-60°F pour point
APPLICATIONS
AMSOIL Synthetic 2-Stroke Injector Oil is recommended for use in all two-stroke outboard motor and snowmobiles and where API TC and NMMA TC-W3 oils are specified. Meets the requirements for warranty protection protection by BRP®/Evinrude®/Johnson®/Ski-Doo® • Polaris® • Mercury® • Arctic Cat® • Yamaha® • Suzuki® • Kawasaki® • Mariner® • Force®
Use as injection oil or 50:1 pre-mix (2.6 oz. per U.S. gallon of gas).
For Evinrude factory-lean setting, use AMSOIL HP Marine Synthetic 2-Stroke Oil.
COMPATIBILITY
AMSOIL Synthetic 2-Stroke Injector Oil is compatible with most conventional and synthetic two-stroke oils; however, for best performance, mixing oils should be minimized.
HEALTH AND SAFETY
This product is not expected to cause health concerns when used for the intended applications and according to the recommendations in the Safety Data Sheet (SDS). An SDS is available via the Internet at AMSOIL (http://www.amsoil.com/shop/by-product/motor-oil/2-stroke/synthetic-2-stroke-injector-oil/?code=AIOQT-EA/?=zo1856266) or upon request at (715) 392-7101. Keep Out of Reach of Children. Recycle used oil and bottle.
WARRANTY
AMSOIL Synthetic 2-Stroke Injector Oil is Warranty Secure™, keeping your factory warranty intact. AMSOIL Injector Oil is a high-performance replacement for vehicle manufacturer-branded products and is also backed by the AMSOIL Limited Warranty (G1363). Find details on pricing here. (http://www.amsoil.com/shop/by-product/motor-oil/2-stroke/synthetic-2-stroke-injector-oil/?code=AIOQT-EA/?=zo1856266)
<tbody>
TYPICAL TECHNICAL PROPERTIES
Kinematic Viscosity @ 100°C, cSt (ASTM D445)
6.9
Kinematic Viscosity @ 40°C, cSt (ASTM D445)
35.3
Viscosity Index (ASTM D2270)
161
Pour Point °C (°F) (ASTM D97)
-51 (-60)
Flash Point °C (°F) (ASTM D92)
88 (191)
Fire Point °C (°F) (ASTM D92)
88 (191)
SAE J1536 Fluidity/Miscibility Grade 4 Arctic Climate (17,000 cP max @ -40°C)
Pass
</tbody>
