View Full Version : looking for a 2 groove, press on power steering pulley.
cactuss4
09-09-2013, 04:34 PM
Trying to move my BBC to a metric, JGC setup and got a power steering pump from a 90 Chevy pickup, but no pulley
tory
72BBSwinger
09-10-2013, 01:01 AM
I believe what you want is a gm saginaw type 2 pulley. EBay or google that in a 2 groove v belt. Verify your shaft diameter which hopefully is .664 and make sure the pulley is like .662.
astroracer
09-10-2013, 02:25 AM
The late model press-on pulleys are usually .750 diameter shafts. The earlier slip-on style, bolt-on pulleys are usually .663 to .665.
Mark
72BBSwinger
09-10-2013, 02:59 AM
I thought that depended on if it was a bushing or bearing style pump.
astroracer
09-10-2013, 03:52 AM
Good point... The OP will need to verify shaft diameter. It does make a difference if the truck was equipped with hydroboost. He will need to verify that also.
Mark
