jtwoods4
09-08-2013, 01:27 PM
I am a little confused. I have a 1970 Trans Am and the rear brake lines that attach to the left and right brakes are 3/16 lines with the standard invert flare 3/8 connectors. I have a set of wildwood disc brakes (D154) that require a banjo fitting with a 10mm x 1.5 thread. My stock brake lines run down the axle housing to the left and right brake.
If I order the wildwood flex line kit with Banjo fittings then I am stuck with about a foot of flex line. My hard lines already run the length of the axle housing to the brake calipers. What kind of adapter kit do I need in order to connected the inverted flare on the hard line to the 10mm x 1.5 calipers?
Or do I just need to get some really short 3/16 lines and connect them to the flex lines about half way down the axle tubes. Why would I want a flex line running down my axle tube instead of a stainless steel hard line. I am so confused on how to set this up.
Here is a picture of my existing line setup (not my car but you get the idea)
81957
-John
81957
-John
