rickpaw
08-22-2013, 06:22 AM
Hi guys,
I got the engine running on my car the other day, and according to the fuel pressure gauge, the fuel pressure is low. Quick specs:
-5.3l/4l60e combo drop out from a 01 Chev pickup. Running LS1 intake/injectors/ECM. Truck coils. Otherwise bone stock. ECM/harness from PSI.
-Fuel system consists of Tanks Inc FI tank, Aeromotive 340 pump, Wix C5 reg/filter near tank, Finch's dual tank vent. 3/8 hard lines with -6 an lines going to the rails/fuel pump.
-Mechanical fuel pressure guage mounted inline prior to fuel rail inlet.
The issues:
-1) The fuel pressure seem to be low, around 40 psi at idle. Idle speed 600 rpm. It's my understanding that LS engines won't run or run poorly with pressure less than 58 psi. I checked for voltage at the pump, and it's getting 13.5V. Alternator puts out a bit over 14V. Fuel pump is wired thru a relay, with 10 gauge power/ground wires. Engine runs fine though, with no codes showing. I checked for blockage at the pump inlet (none), all the hose connections at the pump are tight. Do you think the gauge maybe bad and showing inaccurate reading? It's a cheap oil filled mechanical gauge I bought from amazon.
-2) Fuel pressure drops to zero after shut down, and I have to let the pump run a bit (2-3s) to prime the system back up. Is this normal, or do I have to use some sort of a check valve?
Thanks for the help/inputs.
The issues:
