View Full Version : C10 truck rear sway bar
hag6888
08-21-2013, 10:34 PM
Why are rear sway bars effective ?
Jon @ Hotchkis
08-22-2013, 10:20 AM
This might be a candidate for shortest question with the longest answer. To keep it simple:
All cars will want to roll to a certain extent when cornering from the lateral loads. Sway bars (anti roll bars) are used to fight this roll and help keep the car flatter when cornering. A rear sway bar, in the right application, will help to achieve the desired roll-resistance of the entire suspension setup, and they can also be used to help turn the car when cornering by reducing the inside-rear tire's overall grip level, all things considered.
I'm sure someone (Ron Sutton) can elaborate on this better than I.
custom 68
08-22-2013, 01:12 PM
my short answer it is a good thing. Hotchkis plus others will have a great performance options but check this link if you have the ability to make some of the parts yourself. I did this and seemed to get some great help from it. I had to remove it on one of my trips since after I loaded the truck down some I cot into a clearance issue and the rest of the trip did not seem as stable. I have since modified it to fit my needs better. There are probably better options but this is a great start and will save a few bucks for other mods.
Installing a Camaro Rear Sway Bar on your truck (http://www.low69cst.freeservers.com/CamaroBar.htm)
Dave
