View Full Version : '69 Chevelle - 9.5" Front wheels possible?
Barrrf
08-21-2013, 11:13 AM
Has anyone done this? I really only ever see X8's.
I found a rediculously cheap set of 19x9.5s - forged. I would have to run a spacer (DNW opinions on spacers please) but not sure if I ran maybe a 275/30 or something if it would fit.
I would appreciate any experiences anyone might have.
Thanks.
Barrrf
08-27-2013, 11:41 AM
A bump for good measure
raustinss
08-27-2013, 07:27 PM
It will I can't recall what spacing but I did a search on the googles...lol and found you should be able to run 275 in the front and 335 in the rear...now if you lower the rear that changes to somewhere around a 295 do to the shape of the wheelwell making the tire rub.
Best of luck Ryan
Barrrf
08-28-2013, 04:33 AM
I tried the google. Couldnt find much that made me comfortable.
andrewb70
08-28-2013, 05:26 AM
I think it can and has been done. You will need 5.5" of backspacing to run a 275/35-18 tire.
raustinss
08-28-2013, 02:12 PM
That's about what my Lil brain was thinking...lol thanks for the info Andrew hopes it works for him
Typhoon1015
08-28-2013, 02:19 PM
I am running 275's on the front of a 66 chevelle if that helps, 18x9.5 Everything clears except for the huge turbo hanging into the fender well.
Carvin velle
08-28-2013, 07:58 PM
Ditto what Andrew said! I have a 18x9.5, 5.5" BS and a 275/35 tire. Can check out a few photos at the link below to give you an idea of the ride height...no rubbing inside or outside.
https://www.pro-touring.com/cars-general-technical/wheels-tires/eric-moscos-1970-chevelle-forgeline-gz3-wheels-100179.html
