View Full Version : Workbench questions: Size and surface materials
Larry Callahan
08-16-2013, 01:30 PM
Since I now have a real garage (small but real) I want to build a wall with cabinets and a work bench.
What works for you or what do you hate about yours? Should I go 6' or 8'? Steel top? Butcher block? Laminate?
I know I want to bolt a vise to it and the bench to the ground. I also want to be able to hammer on it and bend stuff in the vise without the bench collapsing or moving.
I also need to store a tall chair under it so I can sit at it and solder or?????
Oh, and I think about 20" deep is as far as I can go.
72BBSwinger
08-16-2013, 01:39 PM
My bench top is 12' long and made out of 1 1/2 solid oak doors lol! It works excellent and I also wrapped it in 20 gauge galvanized sheet. So its now chemically resistant as well.
sccacuda
08-16-2013, 04:51 PM
I would suggest two tables. A "clean" and "dirty". I use a steel table as my dirty, vice, bang on it, etc... that also incorporates a small channel on the back that dumps into a 5 gallon bucket. I have several used restaraunt stainless tables as my clean work surfaces. They are available in all different sizes, with or without back splashes and are super easy to clean.
icemanrd19
08-16-2013, 05:33 PM
post your work space. Im researching the same thing now. Maybe we can help each other
tommycomfort
08-16-2013, 05:40 PM
Larry, I have multiple benches and am getting ready to build a new one for the new garage/shop. I'm looking at an 8' section of bowling alley. Should be well sealed and durable.
Ron Sutton
08-17-2013, 08:41 AM
X2
I always need a place to beat, grind & shape metal. And you need a clean, smooth surface for assembly, lay out, etc.
72BBSwinger
08-17-2013, 10:09 AM
I have my work bench and then I have my welding table. And they're probably 20 ft apart. I recently bought a flame retardant blanket that I plan to put up as a curtain around the welding table.
