usc2001gc
08-28-2005, 02:59 PM
1st. Will a 10.5" clutch (maybe Centerforce II or dualfriction or equiv.) hold up behind a MILD 402 BB, TBI with a TKO 500/ 2.73 rear (later upgrade to a 3.42 or so)?? (71 chevelle)
2nd. Would this flywheel work with the above combination??
( My main concern is weight...I read somewhere that a light-weight flywheel makes the car a little difficult to initially pull off from a stop with out spinning the tires.)
Part Number: 14085720
Manufacturer: GM Performance Parts
Diameter : 12.75"OD
Teeth : 153
Year : 1955-1985
Crank Bolt Pattern : 3.58"
Clutch Bolt Pattern : 10.4"
Weight: ~15lb
I already have the smaller bellhousing (GM 3840383), the above flywheel (new) and a new Centerforce 10.5" disc. If I can keep my cost down and use the parts I already have, I can justify ordering the TKO to my wife. :attn:
Diameter : 12.75"OD
Teeth : 153
Year : 1955-1985
Weight: ~15lb
