View Full Version : Starter Bolt Fell Out!
TheRoaringEagle
08-28-2005, 10:27 AM
I was using a CSR Mini Torque Starter and it kept coming loose. It had an adapter for my 400 staggered bolt design. I put the stock starter back on with new starter bolts and the engine turned great. Then after a few weeks the starter bolt outboard of the engine fell out. It looks as though the threads are gone in the block.
How do I fix this? I was thinking of using a long bolt that went through the mounting hole and using a nut to tighten it down... I didn't have a starter brace on and I'll be putting it one one soon. Anybody in the San Francisco area know where I could get this fixed? (threads on block)
Maxoctane
08-28-2005, 10:46 AM
you could helicoil it, not too difficult
TheRoaringEagle
08-28-2005, 12:57 PM
i looked helicoiling up, do you happen to know the size of the starter bolt?
08-28-2005, 01:26 PM
coarse thread 7/16"
Maxoctane
08-28-2005, 08:58 PM
I'm pretty sure Sears has a kit that fits a variety of sizes, shouldn't be too expensive either. You can recoup your cost by rethreading your friends stripped bolt holes! :yeah:
TheRoaringEagle
08-28-2005, 09:46 PM
thanks guys, you guys are awesome. i completely forgot about my sway bar too. the mounting hole for the driver's side bracket on the rear part is stripped too and i was going to stuff a larger diameter bolt, but i'm gonna try and helicoil that too.
thanks!!
